Laguna II - Headlight Washers problem - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Electronics
Notices
Electronics In Car Entertainment (ICE), Sat-Nav, lighting, wiring etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Use the drop-down below to display RenaultForums in the language of your choice.
Electronics
Reply
Thread Tools Display Modes
Old 1st October 2007   #1
xant14
xant14 is
has no status.
Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
just to say hello, but, also the reason I joined, took my car for a service, cutting a long story short here, any way they said the headlight washers werent working, which were 2 or 3 day before, and the previous year befor that. Is there any thing that might have been done to stop the washers working? a fuse or something?
I can tell you the full story of the service(cons! ?) if you wanna hear.
Currently in xant14's garage:
2003 Renault Laguna II 1.9dci initiale
xant14 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by xant14
Thread Forum Last Poster Replies Views Last Post
Turbo.. gone again? Engines billpine 9 1682 6th July 2011 12:49 AM
Laguna lumpy at 1900 rpm Engines xant14 8 2289 31st August 2010 06:06 PM
Laguna Door lock Assembly Bodywork xant14 6 3524 16th September 2009 07:58 AM
Laguna II - Headlight Washers problem Electronics xant14 4 2356 1st October 2007 06:34 PM
Sponsored Links
Advertisement
Old 1st October 2007   #2
Donald
Donald is
mad
Platinum member
Technical Supremo
Fishing the Sea Champion
Donald's Avatar
Nominated 1 Time in 1 Post
Nominated TOTW/F/M Award(s): 11
Hello and welcome to the forum,iam sure there will be a fuse for it,i hope this helps Donald
Currently in Donald's garage:
2005 Mercedes Benz C200 Classic SE Kompresser & 1998 Fiat Cinquecento Fire Sporting,some may say i could do far better?,i say i could do far worse.
Donald is offline   Reply With Quote Quick reply to this message
Old 16th September 2009   #3
xant14
xant14 is
has no status.
Member
Threadstarter
lock problem
hi, back again.. something else is wrong now.. the central locking on the drivers side. Motor is just wizzing, not locking the door. How do I disconnect the outside door handle from the cable?
Old 16th September 2009   #4
Arkadius1984
Arkadius1984 is
has no status.
Junior Member
Arkadius1984's Avatar
Nominated 0 Times in 2 Posts
Talking
when you open the door, on the side, right by the locking mechanism you can find a round slot, just spin it with screwdriver, and the door handle will be disengaged, but you can still open the door from inside. I reckon that you are having same problem as I've had couple of weeks ago- snapped small locking bit. The thing is that it is quite hard to get that bit alone, as the dealer and suppliers can sell only the whole actuator thing, so the best solution is to get to your local scrapyard and find used locking mechanism, and fit it. I have found mine on ebay, for 5 quid, as the cover was damaged, but the bit I needed was untouched good luck with repair
Currently in Arkadius1984's garage:
Renault Laguna 2003 1.9 DCi Initiale, Honda Civic 2008 5dr 2.2 CDTi EX
Arkadius1984 is offline   Reply With Quote Quick reply to this message
Old 17th September 2009   #5
xant14
xant14 is
has no status.
Member
Threadstarter
Oh... I had seen that bit... and it did seem floppy and wobbly... But too late now.. because the whole unit is wrecked now. I had tried to unclip the plastic from the metal lock part, and it sort of disintergrated.
Thanks for this reply Arkadius. Any future troubles I may leave a few a few days until I have seen replies.
Reply
Tags
headlight, laguna, problem, washers
Quick Reply
Message:
Options
Post Icons
You may choose an icon for your message from the following list:
Register Now
In order to be able to post messages on the Renault Forums :: Independent Renault forum forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
What's current in your garage?
Please share a bit of information about what you drive. For example: 2004 Renault Laguna II 1.9dCi. This is in addition to the model field above. This will appear in your signature so that our members know what you drive
Where are you?
What model do you own?
You must fill this field in
We'd like to better understand our user demographic. We'd be grateful if you could choose the model you currently drive from the list below. If you have more than one car, please choose the model representing your main car. This is for demographic purposes
Where in the country are you?
This field allows us to determine roughly where our members are. We have some region specific activites coming up in the future
What's your team?
Who do you support? Setting this option will show your allegiance in your posts. Leave this field blank by all means
Panic Button - On/Off Switch
The Panic Button is an icon that resides at bottom right hand corner of every post. If your Boss (or maybe the Wife) turns up, clicking the Panic icon immediately sends you to another web site of your choice.
Select the appropriate button to turn this feature On or Off.
Panic Button - URL Jump
This is the URL (web address) of the web site that is jumped to when you click on the Panic Button. Make sure you use the full address including the http://. For example:
http://www.Google.co.uk
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
Copyright © 2005-2015 RenaultForums
