Renault Megane 1 - Misfire/Coil Problems - Page 3 - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Engines
Notices
Engines Engines and other oily matters
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Use the drop-down below to display RenaultForums in the language of your choice.
Engines
Reply
Thread Tools Display Modes
Old 26th August 2008   #11
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 1 Time in 1 Post
Nominated TOTW/F/M Award(s): 18
Theres no point in disconnecting the the coils one by one to check for a misfure as they are wired in pairs,so if you disconnect one you disconnect a pair.The way to check for a misfire is to reach down at the front of the engine and disconnect each injector in turn,this will show up the cylinder that has the problem.
__________________
I'd rather push my Alfa than drive a BMW....
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 26th August 2008   #12
david.gibson
david.gibson is
has no status.
Junior Member
Threadstarter
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Smile
Quote:
Thanks. I did not know that. I will do that test tomorrow.
Thanks again
Currently in david.gibson's garage:
2001 megane cabriolet 1600 16v
david.gibson is offline   Reply With Quote Quick reply to this message
Old 27th August 2008   #13
david.gibson
david.gibson is
has no status.
Junior Member
Threadstarter
Quote:
Thanks again
I have tested and removing the injector plugs made the engine run worse on all plugs so I assume that the coils are ok.
On the exhaust behind the first box there is a sensor with 4 wires. Is this the Lamda sensor? Mine looks like the wires have been cut off as there are no wires going into the harness. Couls this not be part of the problem?
Reply
Tags
megane, misfire or coil, problems, renault
Quick Reply
Message:
Options
Post Icons
You may choose an icon for your message from the following list:
Register Now
In order to be able to post messages on the Renault Forums :: Independent Renault forum forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
What's current in your garage?
Please share a bit of information about what you drive. For example: 2004 Renault Laguna II 1.9dCi. This is in addition to the model field above. This will appear in your signature so that our members know what you drive
Where are you?
What model do you own?
You must fill this field in
We'd like to better understand our user demographic. We'd be grateful if you could choose the model you currently drive from the list below. If you have more than one car, please choose the model representing your main car. This is for demographic purposes
Where in the country are you?
This field allows us to determine roughly where our members are. We have some region specific activites coming up in the future
What's your team?
Who do you support? Setting this option will show your allegiance in your posts. Leave this field blank by all means
Panic Button - On/Off Switch
The Panic Button is an icon that resides at bottom right hand corner of every post. If your Boss (or maybe the Wife) turns up, clicking the Panic icon immediately sends you to another web site of your choice.
Select the appropriate button to turn this feature On or Off.
Panic Button - URL Jump
This is the URL (web address) of the web site that is jumped to when you click on the Panic Button. Make sure you use the full address including the http://. For example:
http://www.Google.co.uk
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
Copyright © 2005-2015 RenaultForums
