vacuum hoses - Page 3 - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Engines
Notices
Engines Engines and other oily matters
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Use the drop-down below to display RenaultForums in the language of your choice.
vacuum hoses
Engines
Reply
Thread Tools Display Modes
Old 20th May 2010   #11
danw20
danw20 is
has no status.
Member
Threadstarter
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Re: vacuum hoses
there should be an attachment on this thread, its a photo of the part i'm talking about. as you can see, just below the elec connector, theres a thing, that looks like a vacuum pipe goes on to.
thanks
Click image for larger version
Currently in danw20's garage:
Renault Laguna II 1.9 dci with smokey engine
danw20 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 25th July 2010   #12
Robsx
Robsx is
has no status.
Junior Member
Re: vacuum hoses
Quote:
Originally Posted by danw20 View Post
Hi all,
Renault laguna 1.9 dci
I've just noticed that I seem to missing a vacuum hose on the vacuum control solenoid, the black thing that sits behind the inlet manifold, there is a electrical connection going into it, and just below it seems to be a outlet for a hose, I have had a good look around and cant find anything that might go there, unless when i replaced the turbo i put all the other hoses cant incorrectly.
Can someone please help, as its been bugging me for a couple of days now. It would be extra helpful if anyone had any photos or tell me when to look at the other end.
Thanks all
I hope you've got it sorted now! But I thought I'd just add this in case, like me any one else is searching with out help!
I'm fitting a new turbo to my new Laguna and also noticed the lack of vac pipe on the solenoid valve
After hours of searching for a diagram or info on how the vac pipes are routed, I had an idea! Quick check on autotrade and viola one at a traders a couple of miles away. So off I pops and would you believe it thats the same???? So it seems its the norm!!! I just cant understand why
I'll do some more digging and post any info and try and get some pics for future reference.
Currently in Robsx's garage:
2002 1.9dci
Robsx is offline   Reply With Quote Quick reply to this message
Old 25th July 2010   #13
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Re: vacuum hoses
The black cylinder behind the inlet manifold is a vacumm reservoir (tank). Its vacuum is generated by the vacuum pump on the end of the camshaft - one pipe in. As far as I remember there should be two outlets - one to the turbo solenoid actuator and another to a solenid (located just beside the tank) which activates the stop damper valve.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Reply
Tags
hoses, vacuum
Quick Reply
Message:
Options
Post Icons
You may choose an icon for your message from the following list:
Register Now
In order to be able to post messages on the Renault Forums :: Independent Renault forum forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
What's current in your garage?
Please share a bit of information about what you drive. For example: 2004 Renault Laguna II 1.9dCi. This is in addition to the model field above. This will appear in your signature so that our members know what you drive
Where are you?
What model do you own?
You must fill this field in
We'd like to better understand our user demographic. We'd be grateful if you could choose the model you currently drive from the list below. If you have more than one car, please choose the model representing your main car. This is for demographic purposes
Where in the country are you?
This field allows us to determine roughly where our members are. We have some region specific activites coming up in the future
What's your team?
Who do you support? Setting this option will show your allegiance in your posts. Leave this field blank by all means
Panic Button - On/Off Switch
The Panic Button is an icon that resides at bottom right hand corner of every post. If your Boss (or maybe the Wife) turns up, clicking the Panic icon immediately sends you to another web site of your choice.
Select the appropriate button to turn this feature On or Off.
Panic Button - URL Jump
This is the URL (web address) of the web site that is jumped to when you click on the Panic Button. Make sure you use the full address including the http://. For example:
http://www.Google.co.uk
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
Copyright © 2005-2015 RenaultForums
