Renault Laguna 1 - Nearside Wishbone Removal - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Steering and Suspension
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Reply
Thread Tools Display Modes
Old 16th January 2010   #1
Davido
Davido is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Renault Laguna 2L RTI 1998. I have removed the centre bolt & the ball joint from the nearside front suspension bar, however after removing the nut on the rear fixing the bolt just turns and cannot be removed. The bolt seems free turning easily but just will not come out. Any ideas would be greatfully received.
Currently in Davido's garage:
1998 Laguna 2l RTI
Davido is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Davido
Rear Window heater Electronics VelSatisfied 2 1154 10th February 2010 08:54 AM
Laguna 2L RTI 1998 Front headlights Electronics Davido 3 1192 17th January 2010 02:02 PM
Renault Laguna 1 - Nearside Wishbone Removal Steering and Suspension Davido 13 7177 16th January 2010 04:57 PM
Sponsored Links
Advertisement
Old 16th January 2010   #2
mord
mord is
not a complete idiot, some parts got Leftbehind,...(in the UKraine)
Platinum member
mord's Avatar
Nominated 2 Times in 10 Posts
Nominated TOTW/F/M Award(s): 3
Re: Nearside suspension arm removal
hi
sorry but that didnt make any sense
have you disconnected the ball joint from the hub ok?
or is it the lower arm main bolts where it connects into the subframe and chassis your having issues with?
if its the pin in the ball joint thats refusing to release, use a chisel(or screwdriver) and hammer to knock it out.
there is a special tool to break ball joints free, its a slotted chisel (with or without a clamp with bolt to allow manual winding to force the ball joint off the hub)
if its the main arm suspension bolts then you have a problem, you may have to cut the chassis open to remove the arm (i dont think there is any way to get at the nut behind there), and replace it with stainless steel (at least 2 layers of 1.0-1.5mm thickness (its structural so must be reinforced and seam welded) with a new nut welded inplace behind them.)
this will involve fitting the arm on to get the position of the bolt/plate correctly postiioned.
__________________
Currently Breaking 2001 Scenic 1.9Dci
(F9Q-732) complete engine and turbo & fittings/sensors in GWO available
everythings gotta go....
cheap prices, everythings working except the clutch.
Currently in mord's garage:
The CreditCard Holes sooo DEEEEP NASA have put up warning signs about a black hole on the Driveway: update, the driveway and home have fallen in...
mord is offline   Reply With Quote Quick reply to this message
Old 16th January 2010   #3
roby37
roby37 is
has no status.
Diamond member
Nominated 1 Time in 1 Post
Not familiar with the Laguna but sounds like the rubber and one of the metal sleeves on the joint bushing have parted company allowing the bolt to turn. The inner metal sleeve of the bushing has corroded and is "stuck" to the bolt preventing its extraction. No easy answer, first soak the bolt/sleeve with WD40, releasal or similar (diesel if nothing else). Then apply some brute force, blunt punch and hammer to the thread end of the bolt or chisel then ball joint splitter or similar to the hex end. No easy answers unfortunately!
Currently in roby37's garage:
2005 Grand Scenic 1.5dCi
roby37 is offline   Reply With Quote Quick reply to this message
Old 16th January 2010   #4
mord
mord is
Platinum member
mord's Avatar
the one that goes through the subframe can play up and be a pita to remove, usually needing the subframe to be dropped to enable access to the nut on the top.
Old 17th January 2010   #5
Davido
Davido is
has no status.
Junior Member
Threadstarter
Quote:
Thanks I agree that is the problem but I've tried all your suggestions except the ball joint splitter . Unfortunately there is not enough room to give the thread end a good smack
1998 Laguna 2l RTI
Reply
Tags
arm, laguna, nearside, removal, renault, suspension, wishbone
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
