Hey Y'all
After doing an extensive search on the forum, & finding nothing specific.
I wonder if you can help.
The front brakes sound & feel as though they are grinding when braking, so i thought I would check and replace the front pads.
However, whilst looking at the Caliper after getting the wheel off, I can only see the Lower bolt, which seems to be a 13mm, but when trying to undo it using a 13mm socket it seems a tiny bit too big as the socket rounds the edges.
A 12mm is definately too small & a 1/2" is also too small. Thats the first problem.
I might try an adjustable.
Anyway, how does the upper bolt undo?
Is it sandwiched in between the rubber & the caliper.
Anyone got any pics please?
Its a Kangoo Van 2000, W reg. Diesel. Blue.
E
E
