cant get rear fog light to work fuse is ok bulb is ok no power at multiplug reverse light on same plug works ok switch on stalk when turned on getting live feed at fuse so the problem lies between fusebox and multiplug i assume any ideas folks
took live feed from fuse to live side of fog bulb holder and buried cable below ply just for now mot in morning have it working will investigate at a later date
Related Threads
Independent Renault Forums
1.5M posts
207.7K members
Since 2005
