#1
hi can someone supply the head bolt torque settings for 1.9 dci 2001 laguna
many thks
anthony
#2
anyone????
dont want to be tightening them in the dark?
#4
ok . many thks, what the hell are degrees? i have to turn it by 100 degrees by hand , using a protractor or somehting?
many thks
#5
Normally you use a wrench with the angles marked on it. Failing that....
45 degrees is 1/8 of a turn
90 degrees is 1/4 of a turn
180 degrees is 1/2 a turn
360 is a full turn etc etc
100 degrees will be just over 1/4 of a turn.
