#1
Mar 10, 2015
Dear All,
Can anyone explain how to remove the drivers side rear light cluster on a MK1 Scenic 1999-2003 model.
A lovely person smashed mine out and I got another one wringing its way to me soon!
Thanks for any heads up
#2
Mar 10, 2015
I've replaced many parts (blind) as such.
I would wait until the part arrives, then inspect it carefully not only for the location of the mounting points, but also what type of mounting is used.
That way, you will only remove the minimum of trim you need to get the unit swapped over.
HTH,
Paul
#3
Mar 10, 2015
Thanks for that. Appreciated.
If anyone has any other specific advice, please fire away
0
Reply
#4
Mar 10, 2015
There's limited access to the rear of the lamp by removing a panel inside the rear side cubby hole.
You can get the bulb holder out but not sure if there's enough room to get to the retainng nuts for the lamp.
You might need to remove or loosen the large plastic side trim.
#5
Mar 11, 2015
Thanks All..
I was wondering if anyone has actual replaced their?
