megane diesel injection fault warning light - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 27th December 2010   #1
whostolemyhair
whostolemyhair is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hello all. I have an 05 megane 1.9 dci130. Over the last couple of weeks the engine has sounded slightly rougher and a warning light has come on saying 'injection fault...stop' 3 times. If i turn the engine off and restart, it doesnt come on again until i accelerate fairly hard. The last time it happened the engine cut out. Having restarted the car the warning did not come back on as i kept the revs low so managed to get home. Any ideas as to what the problem may be...anything other than fuel injector pump death and 2k to repair? Would it be worth my while using a local small garage and their diagnostic equipment or is this a job for renault diagnostics? Thanks in advance for your replies and time given.
Currently in whostolemyhair's garage:
2005 renault megane 1.9 dci turbo diesel
whostolemyhair is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by whostolemyhair
megane diesel injection fault warning light Engines terryggg 12 30657 27th December 2010 01:41 PM
Sponsored Links
Advertisement
Old 27th December 2010   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Re: megane diesel injection fault warning light
Sounds like you may have a fuel injection pressure problem or possibly an EGR valve problem.
As long as the garages diagnostic kit is compatible with Renaults they should be able to read the faults. It may also be worth coinsidering a diesel specilist.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to madnoel10 For This Useful Post:
whostolemyhair (29th December 2010)
Old 29th December 2010   #3
whostolemyhair
whostolemyhair is
has no status.
Junior Member
Threadstarter
Thank you, thats a help. I appreciate your reply.
Old 30th December 2010   #4
whostolemyhair
whostolemyhair is
has no status.
Junior Member
Threadstarter
Made a little progress with the problem after having diagnostics done. A code 319 came up as the only fault but the garage didnt know exactly what it was as it is a code peculiar to renault. All the mechanic could tell me was it was something to do with rail pressure fuel regulator function...open circuit. He thought it most likely to be a sensor rather than the fuel pump itself. Could anybody help with what the code 319 is exactly? Thanks for the previous reply to my original question, very much appreciated.
Old 21st January 2011   #5
sean1968
sean1968 is
tired
Junior Member
sean1968's Avatar
Did you find out what the problem was? I have the 1.5 version and am having a similar problem and I dont mind saying im a bit worried. Cheers, Sean
Currently in sean1968's garage:
Renault Mégane 1.5DCi 2005 - Peugeot 307cc 2.0 Convertible 2004
sean1968 is offline   Reply With Quote Quick reply to this message
Reply
Tags
diesel, fault, injection, light, megane, warning, warning light
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
