Camshaft sensor faulty + battery drain. Megane 2004 1.6 petrol - Page 4 - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 2nd January 2011   #16
Colcut
Colcut is
has no status.
Member
Threadstarter
Colcut's Avatar
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Re: Camshaft sensor faulty + battery drain. Megane 2004 1.6 petrol
The entire sensor looks completely different to mine, the wire connecting to yours looks different as well.
Just been looking on another site that has some engine diagrams.
http://i145.photobucket.com/albums/r.../ENGCOMP04.jpg
This says the actual sensor is on the other side of my engine!?
Seems like the plot is thickening
Click image for larger version
Currently in Colcut's garage:
2004 1.6 Megane
Colcut is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 2nd January 2011   #17
Scenic Fidji
Scenic Fidji is
has no status.
Edit
Posts: n/a
Well I don't think that is right? there is no sensor on that side of any of these engines that I have seen?
I have a 201 1.4 Scenic with the K4J engine and as far as I'm aware it's almost identical to the 1.6 K4M. Both engines use the same head gasket and cylinder head bolts, same size engine valves water pump and cam belt. The 1.4 however does not have a de phaser pulley so hence there is no cam shaft sensor of any sort.
My GF has a 2002 2.0 16 valve Scenic Fidji this engine is extremely similar to the K4J and K4M. But from our photos the cam senors are different sizes and located slightly differently.
I have repaired both our MK1 Phase 2 Scenic's 1.4 and 2.0 engines after cam belt failure so feel I know them fairly well. THey also fit these same engines in the Scenic II with some slight differences to the air intake manifolds from what Ihave seen.
Old 2nd January 2011   #18
Colcut
Colcut is
has no status.
Member
Threadstarter
Colcut's Avatar
I do have some sensor where I've marked but haven't been out there and took it out yet.
Tomorrow I'm going to take both things out and do some further research
Would you be able to post a picture of your camshaft sensor if you have one available?
Will be interesting to see what the "thing" is on the right side of my engine is, maybe it's this valve and in the diagram they are swapped around..
2004 1.6 Megane
Old 2nd January 2011   #19
cph1984
cph1984 is
has no status.
Diamond member
cph1984's Avatar
Nominated 0 Times in 1 Post
The small black sensor on the gearbox side of the engine is the camshaft sensor, the thing on the timing belt side is your dephaser solenoid
Sent from my HTC Desire using Tapatalk
__________________
Any advice given is exactly that, do not take it as gospel
Currently in cph1984's garage:
2001 VW Golf TDi
cph1984 is offline   Reply With Quote Quick reply to this message
Old 2nd January 2011   #20
Colcut
Colcut is
has no status.
Member
Threadstarter
Colcut's Avatar
Can you circle it on my picture please? I don't know which side is the gearbox side
2004 1.6 Megane
Reply
Tags
2004, battery, camshaft, drain, faulty, megane, petrol, sensor
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
