Will a 1.9 dti turbocharger fit a 1.9 DCI - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 2nd January 2011   #1
3rigel
3rigel is
has no status.
Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
My 2003 DCI turbo has given up the ghost.
While searching for as cheap a possible replacement I noticed how similar the dti and 2003 dci turbos look. Obviously one is VNT and the other the conventional waste gate but beyond that I'm not sure.
The inlet looks identical.
I have two concerns. 1)Will the cat of the DCI mate correctly with the outlet of the dti one if the downpipe part is removed. 2) will the actuator foul anything as its in a different place.
Has anyone any experience on both cars?
Any help would be appriciated.
3rigel is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by 3rigel
Will a 1.9 dti turbocharger fit a 1.9 DCI Engines madnoel10 5 2552 2nd January 2011 01:26 PM
Megane Internal and external woes after flat... Electronics dalton57 2 1404 17th December 2010 01:15 PM
Please Please Please dont tell me I need a... Interiors 3rigel 10 3123 23rd April 2010 06:59 PM
Can the alterntor be changed without!!!! Engines ScenicDTi 3 1345 1st April 2010 08:55 PM
Sponsored Links
Advertisement
Old 2nd January 2011   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Re: Will a 1.9 dti turbocharger fit a 1.9 DCI
Don't judge suitability by looking at pictures on-line as many advertisesr just use any pic to portray what they are selling.
You'll need to match the make and serial number to be certain as they vary quite a bit depending on the bhp of the engine.
There is a vast difference in performance between the conventional and variable nozzle or blade type especially at low rpm.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 2nd January 2011   #3
3rigel
3rigel is
has no status.
Member
Threadstarter
Thanks for your response madnoel10
I am not that experienced in turbos. In my head I had decided that amount of boost would be controlled by the wastgate actuator which inturn buy the ecu and sensors. I thought if anything I would lose at the top end.
I used to own a dti before the dci and think I could live with a slight performance drop.
Will it actually fit though?
Old 2nd January 2011   #4
madnoel10
madnoel10 is
has no status.
Technical Supremo
Whilst it may physically fit it's internal and external control systems are different.
Renault have a habit of changing turbo types across the same model so it's best to stick with what is original.
Honda Civic 1.4l
Old 2nd January 2011   #5
3rigel
3rigel is
has no status.
Member
Threadstarter
I know you are right about me sticking with the original and I may yet, I've put an offer in on a couple.
Are you at all confident that the dti one would line up bolt wise?
Reply
Tags
dci, dti, fit, turbocharger
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
