Renault Megane Fan Belt Adjustment - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 27th January 2011   #1
treecol
treecol is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Can any of you tell me how to adjust the fan belt on a 2002 1.6 16v fidji Megane, please?
Also is there a special tool for adjusting it? Many thanks if you are able to help.
treecol is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by treecol
Renault Megane Fan Belt Adjustment Engines simon1987 4 11743 27th January 2011 06:28 PM
Hello Welcome to RenaultForums Recycled Scenic 1 596 27th January 2011 06:04 PM
Sponsored Links
Advertisement
Old 27th January 2011   #2
S80
S80 is
has no status.
Diamond member
Nominated 0 Times in 1 Post
Re: Renault Megane Fan Belt Adjustment
The belt has a spring-loaded tensioner, which requires no adjustment. To remove the belt, the tensioner has to be 'forced' back against spring tension (using the pulley's centre bolt), then locked in place with a rod slid into a hole for this purpose.
The driven pulleys on alternator etc. have six grooves, but the belt is a 5-peak type - which must be fitted to the 'outside' grooves on all pulleys.
Currently in S80's garage:
Megane I Phase 2 1.8 5dr
S80 is offline   Reply With Quote Quick reply to this message
Old 27th January 2011   #3
treecol
treecol is
has no status.
Junior Member
Threadstarter
Thanks for the reply. I've acctually just taken off the altenator as it's going to be reconditioned, I undid the three bolts which secures the alternator on. So how do i adjust the tensioner when i put the altenator back on? Thanks in advance.
Old 27th January 2011   #4
S80
S80 is
has no status.
Diamond member
Hi treecol,
As mentioned, there is no 'adjustment', the tensioner pulley is spring-loaded - didn't you notice it release when you removed the alternator?
Anyway, you'll need to lock the tensioner first. There's a 13mm bolt head in the centre of the tensioner pulley - get a spanner on it and turn it anti-clockwise to 'wind' the tensioner back against spring tension. There is a hole in the body of the tensioner, through which you must insert a suitable locking rod - an Allen key works well. Shine a torch in there before you start to see how it works.
Once the tensioner is locked, you can fit the belt. I would strongly suggest you get a new belt - they have a nasty habit of shredding , and getting into the timing belt area (I speak from bitter experience!).
Make absolutely sure the belt is routed correctly, and that the 5-peak belt sits on the 'outside' five grooves on the drive pulleys - there must be an empty groove nearest the engine block.
Using that 13mm spanner on the tensioner pulley, take the strain off the locking rod, remove the rod, then slowly release the spring to tension the belt.
Then use a socket on the crankshaft pulley retaining bolt to rotate the crank a few times (clockwise looking at the pulley) - checking that the new belt runs true.
Sounds long-winded, but it isn't really - but get it wrong and nasty things can happen
Old 28th July 2014   #5
simon1987
simon1987 is
has no status.
Junior Member
Hi just trying to do this fan belt on a 1.4 16v got a 5pk1750 belt can anyone confirm this is the right length belt as when I take the Tension off it still seems a little too tight to go round everything
simon1987 is offline   Reply With Quote Quick reply to this message
Reply
Tags
adjustment, belt, fan, megane, renault
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
