Clio 2 airbag ecu fault, need wiring diagram - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 27th January 2011   #1
Az88
Az88 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi all,
I have bought a clio 2003 1.6 dynamique last week and it has some faults.
One of which is the usual airbag serv light illuminated on the dash which i was told had just appeared after the battery had gone flat... i thought it would be the simple wiggle of the connectors under the seat but it looks as though someone has beaten me to it and hard wired them, one wire appeared broken so i re soldered it and thought that would do the job but no.. light is still on, so i have had it plugged into various diagnostic machines and for some reason it will not connect to the airbag ecu but it will connect to engine management etc, has any one heard of this problem before.
I then removed the airbag ecu and found the words "reset" written on the back so either it hasn't been done properly and someone has killed it or there's some broken wires in the loom due to the crash possibly?
I have sent the ecu off to be reset/replaced but in the mean time i would like to check the wiring under the seat is correct does anyone have a wiring diagram? It appears to have been cut further down the loom under the seat as well for some reason which just confuses things
Also is there anything else i should check before the ecu comes back, as far as i can see the front seat belt pretensioners have bot retracted, but i wouldn't be surprised if possible they have just been unwound again to look as if they haven't fired, is there any way of checking? Also the rear seat belts seem to work fine but could these have triggered also?
Sorry for the long post and if you read this far thanks
Best regards
Aaron
Currently in Az88's garage:
Bmw z4 3.0, Clio 2 1.6 Dynamique
Az88 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Az88
clio steering cracking noise Steering and Suspension o4abiggerhammer 6 5995 3rd February 2011 06:54 PM
Clio 2 airbag ecu fault, need wiring diagram Electronics ktm-mad 5 8031 27th January 2011 09:57 PM
clio 2 door open warning fault Electronics Az88 2 1836 27th January 2011 09:36 PM
Sponsored Links
Advertisement
Old 28th January 2011   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Re: Clio 2 airbag ecu fault, need wiring diagram
Are there actually any air-bags in the car. I have seen covers replaced - the used air-bags being cut out and dumped but anyone so devious usally breaks the warning bulb in the dash. Plus once the air-bag actuator has been triggered a fault will be stored in the ECU.
Obviously the car has not been repaired in acordance with stanard repair procedures - just hope your insurers don't find out.
In the interest of safety and insurance I would urge you to have the system checked by compatible diagnostic equipment. As Renault use a different protocol in their systems not all code readers, etc are suitable.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 31st January 2011   #3
Az88
Az88 is
has no status.
Junior Member
Threadstarter
Hi Noel,
All the airbag areas seem to be fine, no signs of them having gone off although the passenger seat is very difficult to move back and forth on its track, if I slacken the seat runners it frees up so that could be due to the side airbag being deployed or maybe I'm just being pessimistic, is there any other common problems this could be?
I hear what you are saying about the safety aspect and i agree, as soon as i get the ecu back i will take it to Renault for them to check as i have a friend who works on the parts sales, i would just like to check the wiring and as much as i can before hand.
Cheers
Old 2nd February 2011   #4
Az88
Az88 is
has no status.
Junior Member
Threadstarter
Talking Re: Clio 2 airbag ecu fault, need wiring diagram
**FIXED**
I sent the airbag ecu off to be 'reset' by a guy on ebay, i phoned him before and told him that it had been reset before and was not connecting to computer dianostics etc, anyway he has sent out a tested replacement all for £20.
Plugged the new ecu in and the airbag light was still showing but not instantly this time so i gathered the new ecu was working then finding a fault somewhere in the system so turned it all off wiggled some wires, last one i checked was the connector going in to the top of the seatbelt pretensior and hey presto!
Spent many hours sorting this out so i hope it helps others in future!
The Following User Says Thank You to Az88 For This Useful Post:
Lagdti (2nd February 2011)
Old 2nd February 2011   #5
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 1 Time in 1 Post
Thats great news,thanks for the update.
__________________
I'd rather push my Alfa than drive a BMW....
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
Reply
Tags
airbag, clio, diagram, ecu, fault, wiring
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
