Problem removing EGR valve from Megane 1.9DCi - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 29th January 2011   #1
Roasty
Roasty is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi all
Have seen a number of EGR posts here, but wanted to ask if there is a technique to actually remove the EGR valve? According to Haynes and other posts I gather it should just pull out?
Have removed the 3 bolts holding mine in place, but the valve won't pull out. In fact it barely moves - any ideas as to why thsi is or how I can remove it without damaging it?
Reason for doing this is I had a faulty turbo which has now been replaced, but looking into manifold from intercooler hose attachment its really filthy, all bunged up with oily deposits so could certainly do with a clean. Can it seize in place due to oil etc?
Any ideas on how to remove the EGR would be very helpful! Thanks
Currently in Roasty's garage:
Renault Megane 'Fidji' 1.9DCi
Roasty is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Roasty
Problem removing EGR valve from Megane 1.9DCi Engines Ralph 1 6002 29th January 2011 07:06 PM
Megane 1.9DCi turbo charger oil leak Engines madnoel10 2 6525 20th January 2011 01:36 PM
Brake problem on Megane (02) Wheels & tyres madnoel10 1 2312 8th January 2011 02:10 PM
Renault Megane engine mounting Engines 6 12393 30th December 2010 07:19 PM
Sponsored Links
Advertisement
Old 29th January 2011   #2
Ralph
Ralph is
Laid back
Platinum member
Ralph's Avatar
Nominated 2 Times in 8 Posts
Nominated TOTW/F/M Award(s): 4
Re: Problem removing EGR valve from Megane 1.9DCi
Squirt carb cleaner or wd40 if you don't have any round were it joins the manifold then rather than pull it straight out twist it and wiggle it after a wile it should start to pull out.
__________________
Ralph's 4th law of motion states that any dropped object will immediately hide under a larger object.
If you find a fix for your problem please let us know it will help others.
Ralph Nr Fleetwood NW UK.
Currently in Ralph's garage:
Clio 15 DCi 80, Motomorini 3 1/2, Yamaha MT-07, LMS 5MT 3 1/2 inch Gauge.
Ralph is offline   Reply With Quote Quick reply to this message
Reply
Tags
19dci, egr, megane, problem, removing, valve
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
