Megane 1.6 Cam Belt Change - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 2nd February 2011   #1
tcb180
tcb180 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Being an old school ex mechanic and getting on a bit now. I was wondering how difficult it actually is to change the cam belt? Are there any step by step guides on here ? OR Is there a resident expert on here that can do the job at reasonable rates. Not having any keys on the pulleys, or timing marks and special locking tools worries me slightly. I live in s.e. wales and I am a new member on here.
Currently in tcb180's garage:
2005 1.6 Megane. 2003 MG ZS 180 Salloon. 1990 Astra Gte 16v
tcb180 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by tcb180
Poor Performance 1.5 Dci Engines Ralph 2 931 17th August 2012 12:47 AM
Megane 1.6 Cam Belt Change Engines tcb180 15 34430 2nd February 2011 04:27 PM
Sponsored Links
Advertisement
Old 2nd February 2011   #2
Recycled Scenic
Recycled Scenic is
has no status.
Edit
Posts: n/a
Re: Megane 1.6 Cam Belt Change
Hello and welcome to the forum to the forum
To time the camshafts you will need to remove the 2 blanking plugs on the gearbox end of the cylinder head. You will have prize them out. Rotate the engine until the 2 offset slots in the ends of the cam shafts are below the centre line of the upper and lower cylinder head and insert the timing tool.
There is a blanking bolt to the right of the dipstick which you remove to insert the TDC setting pin.
You shouldn***8217;t need to undo the cam shaft sprockets if replacing the belt. It***8217;s best to buy a complete belt kit with tensioner and guide roller as the rollers can also fail. You should get 2 new blanking plugs with the kit. It might also be worth changing the water pump at the same time as this is also driven by the timing belt.
You will have to remove the drivers side engine mounting and jack the engine up and down.
Old 2nd February 2011   #3
S80
S80 is
has no status.
Diamond member
Nominated 0 Times in 1 Post
Recycled is your man
Not sure what it's like on the 2005 cars, but access was a bit fiddly doing my 2001 model.
It's pretty straightforward once you get your head round the 'keyless' pulleys. Don't cut corners, use a new crankshaft pulley bolt and remember to manually turn the engine over when setting the belt tension.
Renault recommend renewing the serpentine (alternator etc) belt whenever it is removed.
Currently in S80's garage:
Megane I Phase 2 1.8 5dr
S80 is offline   Reply With Quote Quick reply to this message
Old 3rd February 2011   #4
tcb180
tcb180 is
has no status.
Junior Member
Threadstarter
Thanks guys. So the cam locking tool just fits on the rear of the shafts to lock them does it? Only I saw one post somewhere with a larger tool locking the front sprockets too? This I believe was on a 172 Clio Sport.
Old 3rd February 2011   #5
Recycled Scenic
Recycled Scenic is
has no status.
Edit
Posts: n/a
Quote:
Yes thats right here is a home made tool being used. The cam locking tool will fit 1.4 K4J, 1.6 K4M,1.8 F4P & 2.0 F4R 16 valve engines.
The cam shaft sprocket locking tool you refer to is for undoing the cam shaft sprockets which you shouldn't need to do if just changing the timing belt. The cam shaft sprockets do have to be removed to be able to remove the upper cylinder head / rocker cover.
Reply
Tags
belt, cam, change, megane
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
