Laguna II - ESP Fault/ABS Sensor? - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 5th February 2011   #1
Jacobite
Jacobite is
has no status.
Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
So my Laguna has had this ESP Fault flashing up for months and months.
I sourced some 2nd hand ABS sensors for the front and replaced them for it to make no difference - still receiving the dash esp fault.
I guess I will now have to replace the rears sensors.
- Does anyone know whether the front and rear sensors are same?
- Are the sensors left or right specific?
- If it's not the sensors what could it be?
Currently in Jacobite's garage:
Renault Laguna II 1.9dCi & Nissan Silvia S15
Jacobite is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Jacobite
Laguna II - ESP Fault/ABS Sensor? Electronics Andrew Saunders 5 6924 5th February 2011 12:37 PM
Laguna II - Rear lock mech's? Electronics Andrew Saunders 1 1376 29th January 2011 02:14 PM
Laguna II: Suspension rattle? Steering and Suspension Andrew Saunders 6 3237 11th July 2010 11:05 AM
Laguna II: 1.9 dCi Bleeders ? Heating & cooling Jacobite 2 1656 28th May 2010 11:12 AM
Sponsored Links
Advertisement
Old 5th February 2011   #2
Andrew Saunders
Andrew Saunders is
Living the dream
Member
Andrew Saunders's Avatar
Nominated 0 Times in 1 Post
Re: Laguna II - ESP Fault/ABS Sensor?
Hi Jacobite,
Not sure if the car would log the fault so may need battery taken off for a few minutes and then put back on and see if that clears it? Dont forget that radio may need a code if you do this ok.
Andy
Currently in Andrew Saunders's garage:
2005 Laguna 1.9 dci Initiale Sport Tourer
Andrew Saunders is offline   Reply With Quote Quick reply to this message
Old 5th February 2011   #3
Jacobite
Jacobite is
has no status.
Member
Threadstarter
Ahh didnt think of that obvious one, will give it a crack.
I did the service reset, but don't think that does anything.
Old 5th February 2011   #4
Andrew Saunders
Andrew Saunders is
Living the dream
Member
Hi Jacobite,
Do you still have your suspension rattle going on and did it start not long after lowering the car?
Andy
Old 5th February 2011   #5
Jacobite
Jacobite is
has no status.
Member
Threadstarter
Suspension rattle was what I thought it was - strut mount top failed eventually.
Because of the tiny movement the shock absorber rod continually banged against the underneath of the strut top mount, the rod eventually smashed through the entire assembly and protruded out the other side bashing the bonnet up
I knew what it was when it eventually failed catastrophically, but near impossible to find beforehand unless pulling the entire suspension apart.
Oh and battery reset didn't fix it.
Reply
Tags
esp, fault or abs, laguna, sensor
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
