Aux Drive Belt Changing - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 5th February 2011   #1
victic
victic is
OK (ish)
Junior Member
victic's Avatar
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Question Aux Drive Belt Changing
Having a spot of bother changing the Aux Drive Belt and Tensioner on a 1998 Scenic 2.0 (F3R 796 engine +PAS+AC).
I can't see (a) how to release the belt tension, and (b) how the actual tensioner works.
My Haynes manual is not very helpful and has no pictures or diagrams for my particular engine model.
The new tensioner has a toothed gear on one side and comes with a new Allen Key bolt.
Can anyone enlighten me on how I change the tensioner and belt.
Victor
Currently in victic's garage:
2001 Scenic 1 P2 2.0 16v Privilege, 1998 Scenic 1 P1 2.0 RXE Manual, 2002 Rover 25 IE 1.4 16v 2dr, 2000 Ford Focus Mk1 1.8 4dr. Ahh Variety be the spice of life!!
victic is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by victic
Scenic 1 Fuel Filter Engines hrg207 2 716 11th March 2013 12:18 AM
Aux Drive Belt Changing Engines Lagdti 5 5852 5th February 2011 05:35 PM
TDC Sensor problem ? Engines victic 2 1606 11th July 2010 11:57 AM
Scenic (98) - Indicators Failed Electronics Repairman44 3 1547 27th May 2010 11:27 AM
Sponsored Links
Advertisement
Old 5th February 2011   #2
pjl 52
pjl 52 is
has no status.
Member
Re: Aux Drive Belt Changing
Hi Victic,
I don't know the F3R but on the F4R espace you have to put a ring spanner on the idler pulley and pull towards you. This releases the belt tension and you can put a alan key through the bracket at the front to hold in position. Look at your new tensioner and check the spring is in tension. If it is nly release when new tensioner and belt are fitted. I am sure somebody with a scenic will come along soon and tell you the official method. Good luck pj52
Currently in pjl 52's garage:
2002 espace expression auto
pjl 52 is offline   Reply With Quote Quick reply to this message
Old 5th February 2011   #3
Recycled Scenic
Recycled Scenic is
has no status.
Edit
Posts: n/a
The auxiliary belt tensioner on the 2.0 16 valve F4R fitted in the later MK1 Scenic is released in the same way as pjl 52 describes for the Espace a cranked ring spanner on the tensioner wheel center nut and rotate clockwise and lock in position as he says.
I would think it must be a similar procedure for the 2.0 8 valve F3R though I think access might not be as easy as I belive the alternator is at the back of the engine?
Old 5th February 2011   #4
victic
victic is
OK (ish)
Junior Member
Threadstarter
victic's Avatar
To help,
this a pic of the tensioner.
Any help would be appreciated..
Victor
Old 5th February 2011   #5
OLD 2.0 SCENIC
OLD 2.0 SCENIC is
has no status.
Diamond member
I Have a similar age 2.0 F3R scenic not auto and no air con and the auxilary belt is tensioned by the alternator, loosening 2 nuts and adjusting with a adjusting screw. there is no other tensioner on the aux belt. Is your alternator in front of the engine like mine? (I think mine is F3R 750)
Currently in OLD 2.0 SCENIC's garage:
1999 MEGANE SCENIC 2.0 RT
OLD 2.0 SCENIC is offline   Reply With Quote Quick reply to this message
Reply
Tags
aux, belt, changing, drive
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
