How do i change air filter housing kangoo 1.9 diesel - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 6th February 2011   #1
BICHONFRISE
BICHONFRISE is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi how do i change the complete air filter housing assembly on my renault kangoo 1.9 diesel .i know how to take the top cover off but what about the bottom cover? Also what valve is inside the air filter housing?quick assiastance greatley appriciated
Currently in BICHONFRISE's garage:
renault clio mk 2,saab 9-3 se cabriolet;ford focus 1.6lx
BICHONFRISE is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by BICHONFRISE
kangoo fuse box removal Engines BICHONFRISE 0 1464 31st March 2011 10:51 PM
how do i change the starter motor on my 1,9 d... Engines jaime1980 1 3134 31st March 2011 10:26 PM
kangoo radiator cooling fan relay [what colour is... Electronics colin39 6 13504 25th March 2011 02:57 PM
How to change a kangoo speed sensor Engines kleijn 2 29002 25th February 2011 06:55 PM
How do i change the fuel cut off switch Engines mr espace 2 2121 10th February 2011 10:27 AM
Sponsored Links
Advertisement
Old 6th February 2011   #2
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 1 Time in 1 Post
Re: How do i change air filter housing kangoo 1.9 diesel
The lower part of the air filter housing is a pain to remove,it's bolted from underneath and the fixings are a real pain to get to.You need a 10mm socket with a couple of long extensions and a ratchet,and then you get under the front of the car with a torch and you should see the two nuts/bolts you need to remove.
__________________
I'd rather push my Alfa than drive a BMW....
Currently in Lagdti's garage:
2 Nissan Almeras.....oh joy is mine.....
Lagdti is offline   Reply With Quote Quick reply to this message
Reply
Tags
air, change, diesel, filter, housing, kangoo
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
