Kangoo diesel filter renew - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 6th February 2011   #1
BICHONFRISE
BICHONFRISE is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
How do i change a renault kangoo diesel filter ;do i just disconnect the pipes from the existing one and fit a new one or do i just lift the cover off and replace the filter in the housing ;but wouldnt air get into the system?if it does during the process do i have to bleed the system?and how would i bleed the system?
Currently in BICHONFRISE's garage:
renault clio mk 2,saab 9-3 se cabriolet;ford focus 1.6lx
BICHONFRISE is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by BICHONFRISE
kangoo fuse box removal Engines BICHONFRISE 0 1464 31st March 2011 10:51 PM
how do i change the starter motor on my 1,9 d... Engines jaime1980 1 3142 31st March 2011 10:26 PM
kangoo radiator cooling fan relay [what colour is... Electronics colin39 6 13552 25th March 2011 02:57 PM
How to change a kangoo speed sensor Engines kleijn 2 29198 25th February 2011 06:55 PM
How do i change the fuel cut off switch Engines mr espace 2 2128 10th February 2011 10:27 AM
Sponsored Links
Advertisement
Old 6th February 2011   #2
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 1 Time in 1 Post
Re: Kangoo diesel filter renew
Does the filter look similar to the one in this thread?.
http://www.renaultforums.co.uk/showthread.php?t=44962
__________________
I'd rather push my Alfa than drive a BMW....
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
Old 6th February 2011   #3
FoxOkay
FoxOkay is
Universal
Nominated 0 Times in 5 Posts
Nominated TOTW/F/M Award(s): 5
On my 1.9 dCi megane I disconnected the pipes and removed the whole housing from the car. Then I replaced the filter and washer, put it back together and on the car. Connect the pipes and use the manual pump under the bonnet untill it goes hard.
Leave it run for a minute and your good to go
Currently in FoxOkay's garage:
2005 BMW 530
FoxOkay is offline   Reply With Quote Quick reply to this message
Old 7th February 2011   #4
topman825
topman825 is
has no status.
Junior Member
Quote:
you have to replace the full filter remove pipes and reconnect to new filter
topman825 is offline   Reply With Quote Quick reply to this message
Reply
Tags
diesel, filter, kangoo, renew
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
