how do i remove egr valve from 2004 scenic 1.9dci - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 16th February 2011   #1
mojokart
mojokart is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
hi all i need help removing the egr valve . i know where it is b ut i need help removing it what are the steps to getting it out because i can get 2 bolts of but cant get near the third how do i get around this / what other components need removed to access this ? all help great appreciated
Currently in mojokart's garage:
renault megane scenic 1.9dci 2004
mojokart is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by mojokart
how do i remove egr valve from 2004 scenic 1.9dci Engines dcikev 6 5684 16th February 2011 04:33 PM
Sponsored Links
Advertisement
Old 16th February 2011   #2
mr espace
mr espace is
turning into mr clio !!
Platinum member
mr espace's Avatar
Nominated 0 Times in 7 Posts
Re: how do i remove egr valve from 2004 scenic 1.9dci
Use a big hammer
only kidding you can get the 3rd bolt out but need nimble fingers i assume it is the one on the back of the manifold you are doing as the front mounted type are prety easy
Currently in mr espace's garage:
espace escort cabriolet subaru legacy clios etc !!
mr espace is offline   Reply With Quote Quick reply to this message
Old 16th February 2011   #3
mojokart
mojokart is
has no status.
Junior Member
Threadstarter
i know this mate but what else needs removed as it wont just slide out because there are things blocking it
Old 16th February 2011   #4
bigegg1964
bigegg1964 is
has no status.
Member
Hi mojokart I've got a file I could send you regarding removinging your egr vale if you wanna give me ur email
Currently in bigegg1964's garage:
Renault Scenic 1.9 dci 54 plate VF1JMRG
bigegg1964 is offline   Reply With Quote Quick reply to this message
Old 16th February 2011   #5
mojokart
mojokart is
has no status.
Junior Member
Threadstarter
#post edited,please refer to forum rules re-exchanging of copyright material via the forum,
Many thanks,
The Mod Team
Reply
Tags
19dci, 2004, egr, remove, scenic, valve
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
