Megane 1.9 cutting out - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 19th February 2011   #1
bernij
bernij is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi this is my first post, im having problems my Megane drives fine no loss of power then just cuts out. After remove and replacing the key card its starts fine. The cutting out is getting more frequent. I have fitted a new crank sensor and also changed oil and air filter both very dirty. Can anyone help my other half is now scared to drive it .
bernij is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by bernij
Megane 1.9 cutting out Engines bernij 1 927 19th February 2011 02:29 PM
Sponsored Links
Advertisement
Old 21st February 2011   #2
bernij
bernij is
has no status.
Junior Member
Threadstarter
Re: Megane 1.9 cutting out
Just had car at the garage its showing fault codes df049 refrigeration sensor circuit and df053 fuel rail press regulator function. Can anyone suggest a next moved been told by a mechanic friend it could be cam sensor causing it to cut out. Any suggestions will be much appreciated.
Reply
Tags
cutting, cutting out, megane
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
