mk1 1.2 8v clio, valve adjustment process. - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 20th February 2011   #1
J.Wright
J.Wright is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Question mk1 1.2 8v clio, valve adjustment process.
Here we go, my first post.
Forgive me if this has been answered before, I haven't managed to find the full explanation as yet though.
Ok, a bit of background, the car had developed quite a bad misfire, so I changed the oil, spark plugs and coil pack, but still had the problem I pulled off a vacuum hose that looked to be connected to the injectors and the engine started revving higher so I gave a quick run around and it seemed to fix the issue, hose back in place all is still ok. Although it's no longer misfiring it still sounds (very slightly) like a misfire, I'm praying this isn't a crack in the head because that might be a little beyond my capabilities, so my next approach is going to be adjusting the valves (they are noisy anyway) and I'm hoping someone can tell me if I've got the right idea, or if I'll go about it all wrong.
Once I have the rocker cover off I need to turn the flywheel,which will raise and lower the cylinders, when cylinder #1 reaches TDC I can adjust the front valve to 0.10 mm and the rear valve to 0.20 mm, using a feeler gauge to measure the gaps.
Then repeat the process on cylinder #4, then #2, then #3.
I'm hoping this is the right idea, one day I'll probably buy the haynes manual but for now if anyone can tell me if I'm right or wrong, and any additional advice, would be great.
Cheers
Currently in J.Wright's garage:
1998 1.6e Scenic
J.Wright is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by J.Wright
Mk1 1.2 clio misfiring Engines ady1234uk 4 1603 6th March 2011 12:55 AM
mk1 1.2 8v clio, valve adjustment process. Engines madnoel10 1 6546 20th February 2011 12:39 PM
Sponsored Links
Advertisement
Old 20th February 2011   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Re: mk1 1.2 8v clio, valve adjustment process.
You're on the right track - just make sure each cylinder is it's compression stroke when at TDC.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to madnoel10 For This Useful Post:
J.Wright (20th February 2011)
Reply
Tags
adjust, adjustment, clio, misfire, mk1, process, tappets, valve, valves
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
