What is a TDC and what are the 'symptoms' of failure? - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 28th February 2011   #1
Tiamai
Tiamai is
has no status.
Junior Member
Tiamai's Avatar
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
And please be nice because it's my first time
Hubby has my old megane diesel estate (megane II?) 2004 plate. For the past few days it has been a stroppy mare in whether it will start or not.
If you unlock it and the dash lights up when the door is opened, it will start. If the dash doesn't light up, it wont... but will start if you use jump leads.
Took it today to get the battery checked, battery is tested and is fine, reconected and it then needs a jump. Spoke to an autoelectrician who suggests trying a new battery. So we do and nope it won't start, old one goes back in and it starts. Luckily we have a screaming toddler so the guy doesn't hang about wanting payment for the almost purchase of a battery we don't need.
So after searching your forums tonight, I keep finding reference to a top dead centre (sensor is it?) failure causing intermitent starting problems. But since I am no good with engines, I can't work out what it does and if it would cause our problems. Wiki failed me. Plus I have homework to do and was hoping someone else would look into it all for me
Suggestions welcome before hubby books it into the £25ph autoelectricians on Wednesday and I have to tell him that I actually spent the emergency savings on this really cute outfit for the above mentioned screaming toddler. And maybe also some shoes that are hidden under the bed...
Currently in Tiamai's garage:
04 megane diesel estate and an 04 sceinic (the wee silver one with the big glass roof, it's an automatic but nothings perfect)
Tiamai is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Tiamai
What is a TDC and what are the 'symptoms' of... Engines roby37 14 9528 28th February 2011 07:08 PM
Sponsored Links
Advertisement
Old 28th February 2011   #2
Recycled Scenic
Recycled Scenic is
has no status.
Edit
Posts: n/a
Re: What is a TDC and what are the 'symptoms' of failure?
Hello and welcome to the Renault Forums
Yes it is a sensor. a Top Dead Centre sensor signal is used by the fuel/ ignition systems on both petrol and diesel cars and measures when usually No1 piston is at top dead centre or in other words at the top of it***8217;s stroke before returning back down the bore.
The ECU then knows when to inject fuel in both diesel and petrol engines and ignite the spark plugs in the case of petrol engines.
The Following User Says Thank You to For This Useful Post:
Tiamai (28th February 2011)
Old 28th February 2011   #3
dave_mezza2006
dave_mezza2006 is
has no status.
dave_mezza2006's Avatar
Nominated 4 Times in 9 Posts
Nominated TOTW/F/M Award(s): 5
The TDC sensor is also called a crank position sensor.
See here for a explanation of what it does. http://en.wikipedia.org/wiki/Top_dead_center
Also look at the bellow thread, it will tell you where to find the TDC sensor and how to clean / replace it. The car and engine may be different to yours but the location and prinicpal is the same.
http://www.renaultforums.co.uk/showt...dc+replacement
Welcome to the forum by the way.
Currently in dave_mezza2006's garage:
2014 Vauxhall Astra Limited Edition 1.4 16v VVT Turbo
dave_mezza2006 is online now   Reply With Quote Quick reply to this message
The Following User Says Thank You to dave_mezza2006 For This Useful Post:
Old 28th February 2011   #4
davesss
davesss is
Calm Cool and Collected
Tourerman
davesss's Avatar
Nominated 0 Times in 2 Posts
Nominated TOTW/F/M Award(s): 3
I doubt it is anything to do with the TDC.
If your starter does not turn over to start the engine it's not the TDC Sensor and The TDC will not cause your dash to not light up.
From what you said it seems more likely to be battery leads or earth or some other connection.
__________________
A problem well stated is a problem half solved !
Currently in davesss's garage:
2002 Laguna Sports Tourer 1.8 Dynamique Moondust VF1KGOB, Fiat Siecento Micheal Schumaker, Kawasaki KLE M/Cycle and a cheap Mountain Bike.
davesss is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to davesss For This Useful Post:
Old 28th February 2011   #5
roby37
roby37 is
has no status.
Diamond member
Nominated 1 Time in 1 Post
I go along with the above post. When it is in no start mode try connecting a jump lead between the battery negative and the engine ( to something substantial and clean) that will test the engine earthing. If still no go connect from battery(neg) to a bare metal part on the body and again try a start.
Currently in roby37's garage:
2005 Grand Scenic 1.5dCi
roby37 is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to roby37 For This Useful Post:
Reply
Tags
failure, tdc, ymptoms
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
