Erratic Idle - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Erratic Idle
Engines
Reply
Thread Tools Search this Thread Display Modes
Old 2nd March 2011   #1
morph3
morph3 is
has no status.
Junior Member
morph3's Avatar
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
My Mood: Breezy
Erratic Idle
Hi, i have a Renault Megane 1.4 16 valve Fidji 52 plate and im sure this is a MK1 as its the older shape.
My car had an erratic idle and we put it on a computer ata garage and it only came up with a faulty Lambda sensor, so i changed the sensor and it still idles erratically, so the next thing i tryed was cleaning the idle control valve out which i was advised to do by a Renault dealership, that did not help so i changed the air filter too.
My car is still idling erratically, is there anything else i should check, bare in mind i have limited knowledge on car engines..... Much appreciate any help
Currently in morph3's garage:
Renault Megane I phase II - 2002 1.4 Fidji
morph3 is offline   Reply With Quote
5 Lastest Threads by morph3
Clunking Noise Wheels & tyres Dwalsh 1 183 16th March 2013 02:40 PM
Rear wheel lock up Wheels & tyres Lagdti 9 1177 14th April 2011 09:00 AM
Coolant Temperature Gauge Engines morph3 1 351 10th March 2011 12:38 PM
TDC Sensor Engines 5 1131 8th March 2011 06:48 PM
Erratic Idle Engines 3 447 4th March 2011 10:26 AM
Sponsored Links
Advertisement
Old 2nd March 2011   #2
scatz
scatz is
gonna try and spend more time on RF this year
Platinum member
scatz's Avatar
Nominated 2 Times in 2 Posts
Nominated TOTW/F/M Award(s): 4
My Mood: Fine
Re: Erratic Idle
Aye, Mk1 Phase 2
Perhaps a coil or two? They are the most common failure on Renaults it appears and will cause erratic idling. However, there are many other things which could also cause the same symptoms!
__________________
FOR SALE IN THE NEAR FUTURE - 2002 Renault Scenic 1.6 Authentique - http://www.renaultforums.co.uk/showt...549#post937549
Currently in scatz's garage:
The purple burble that is the Subaru Legacy GT-B, 280BHP of twin turbo goodness!!!! Also now have a 2002 Scenic 1.6 16v Authentique!!!! Awaiting Delivery of a 2013 2.0 TDCi Titanium X Sport S-Max
scatz is offline   Reply With Quote
Old 2nd March 2011   #3
morph3
morph3 is
has no status.
Junior Member
Threadstarter
morph3's Avatar
My Mood: Breezy
Re: Erratic Idle
Thnks scatz i will try the coils, do you think i should change the spark plugs also and were would i locate the ignition coils, are they easy enough for an amature to replace?
Old 2nd March 2011   #4
scatz
scatz is
Platinum member
scatz's Avatar
My Mood: Fine
Re: Erratic Idle
Coils are directly above the spark plugs, you need to pull them off the plugs to remove the plugs so you can't miss them
You may as well check the spark plugs whilst you are there to see if they give any clue as to which cylinder may be the problem....if indeed it is the problem! Check the gap and condition obviously!
Another 'quick' check is to pull each coil off (or at least unplug the electrical connection to the coil) one at a time to see if there is any change to the engine! If you pull a good one then you should get a miss fire, if you pull a bad one then you'll probably notice no change at all to the engine note/firing! Don't leave anything unplugged whilst the engines running for too long as you may cause damage
Old 2nd March 2011   #5
morph3
morph3 is
has no status.
Junior Member
Threadstarter
morph3's Avatar
My Mood: Breezy
Re: Erratic Idle
I will try that tonight and let you know the outcome tommorow, thanks for the help
Reply
Tags
erratic, idle
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © 2005-2009 RenaultForums
Inactive Reminders By Mished.co.uk and FTP-Anime.com
