Renault Espace 2.2dci Intermittent Fuel Injection Error - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Search this Thread Display Modes
Old 7th March 2011   #1
Mespace
Mespace is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
2004 2.2 Dci Espace.
1. Error code first indicated Turbo booster switch... was changed.
2. Error code then said Air Mass flow scensor... was changed.
3. Pressure tested the main injector pump, ok, no problems.
When driving on the motorway above 60 mph display states Fuel Injection Fault. Car looses a little power. Can recover. Going up hills it can feel like there is a pulsing to the engine. Local garage have now given up of fear of spending all my money and have now sais to go to Renault main dealer...
Since using the correct oil I have not had any EGR valve issues.
Any advice?
Mespace!
Currently in Mespace's garage:
2004 Renault Espace IV 2.2 dci Priv
Mespace is offline   Reply With Quote
5 Lastest Threads by Mespace
Renault Espace 2.2dci Intermittent Fuel Injection... Engines craiul 3 2301 7th March 2011 04:23 PM
Espace IV drives door trim removal Interiors VelSatisfied 1 819 9th July 2009 10:33 AM
Sponsored Links
Advertisement
Old 7th March 2011   #2
mr espace
mr espace is
turning into mr clio !!
Platinum member
mr espace's Avatar
Nominated 7 Times in 7 Posts
Re: Renault Espace 2.2dci Intermittent Fuel Injection Error
This sounds like a case of read codes fit new parts !!
As you have seen this rarely works with dci engines you need live data from the diagnostic machine sounds to me like it could be a vacum fault causing boost spikes making the ecu confused
Have they done a leakback test on the injectors ?
Currently in mr espace's garage:
espace escort cabriolet subaru legacy clios etc !!
mr espace is offline   Reply With Quote
Old 29th March 2011   #3
Mespace
Mespace is
has no status.
Junior Member
Threadstarter
Totally sorted saved £££££
Ok, the 2.2 DCI engine, as fitted to my 2004 2.2 DCI Mk4 has a plastic rocker cover. Now this is a complex plastic, yes, plastic cover that incorporates some of the inlet manifold. What can happen is that this rocker cover warps and you loose pressure. This causes the system to think there is a problem with the injection system... hence the errors. You will see oil round the top of the rocker cover and when warm, air.
Renault quoted over £1000 but then said that this was a part that was covered under warranty and have covered 90% of the costs. So I only ended up with a smallish £114 pound bill.
Note, they have to strip down the whole injection system to get the rocker cover off and the injectors can break.
Hamish
Old 27th June 2011   #4
craiul
craiul is
has no status.
Junior Member
Hi Hamish
Any idea what they did at Renault, got the same problem and three independent garages later, with injectors pipe and seals changed, manifold changed and oil changed still not getting a result.
Is no three weeks since this started and mechanics do not know what to do!
Cheers
Hamish
Currently in craiul's garage:
florinioras@hotmail.com
craiul is offline   Reply With Quote
Reply
Tags
22dci, error, espace, fuel, injection, intermittent, renault
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © 2005-2009 RenaultForums
Inactive Reminders By Mished.co.uk and FTP-Anime.com
