clio timing mark - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
clio timing mark
Engines
Reply
Thread Tools Display Modes
Old 18th March 2011   #1
Ricky
Ricky is
has no status.
Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
clio timing mark
my timing mark doesnt match the haynes manual. its a clio 1.4 8 valve 1998
in the picture below is the midle line on the casing the correct mark?
Ricky is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Ricky
crank seal position Engines tolsen 1 961 18th December 2011 11:37 PM
Stiff clutch Engines Ricky 0 720 29th October 2011 08:06 PM
Clio lumpy idle Engines Ricky 0 1532 20th March 2011 11:43 PM
clio timing mark Engines dejan72 3 5886 18th March 2011 11:12 PM
Clio alternator belt/cam belt Engines Lagdti 1 1390 13th March 2011 08:39 PM
Sponsored Links
Advertisement
Old 18th March 2011   #2
S80
S80 is
has no status.
Diamond member
Nominated 0 Times in 1 Post
Re: clio timing mark
If you're not sure, just whip out No.1 (or 4) spark plug and drop a long screwdriver down there. Turn the crank slowly to carefully determine where TDC is.
The 'dot' on the crankshaft sprocket (at roughly 6 o'clock in your photo) should align with a mark on the outer casing.
Currently in S80's garage:
Megane I Phase 2 1.8 5dr
S80 is offline   Reply With Quote Quick reply to this message
Old 19th March 2011   #3
Ricky
Ricky is
has no status.
Member
Threadstarter
Thanks S80
any ideas what mark should be on the top, i have found the marker on the cam pulley but on the head there is a green dash of paint and slightly to the left you can see remnants of a white paint dot over the top of the N impressed in the head casing. the two marks are very close but proberbly a tooth apart
Old 19th March 2011   #4
dejan72
dejan72 is
automatic
Diamond member
dejan72's Avatar
Pics of the older version 1995 1.4 Clio.
DG
Click image for larger version
ID:	12367   Click image for larger version
Currently in dejan72's garage:
2002 laguna V6 24V
dejan72 is offline   Reply With Quote Quick reply to this message
Reply
Tags
clio, mark, timing
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
