TDC Sensor problem? amongst others!! - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 31st March 2011   #1
Rayzer88
Rayzer88 is
has no status.
Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi everyone, i hope you can help me!
I have a 02 Clio Extreme 1.2 16v which went into the garage just over a fortnight ago to have the lambda sensor and the crankshaft sensor changed. First am i right in thinking the crankshaft sensor is another name for the TDC sensor?
Yesterday morning the car simply wouldnt start..it sounded like the battery was dying so when i came home from work i got some jump leads on it. The engine would crank but wouldn't fire..eventually i got it going but its a pain when i've just had £140 of work done, to have something else go wrong!!
Also the car just doesn't sem to be running right...my fiance has a 1.3 KA and get double if not not treble the amount of miles to a tenner than i do! It seems louder than it used to and sluggish (something i had been hoping the new lambda sensor would sort!)
Thanks so much in advance for ANY help you can give me!
Currently in Rayzer88's garage:
2005 Renault Clio Rush Dci 1.5
Rayzer88 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Rayzer88
Clio dci dynamique Oil leak Transmissions Rayzer88 6 433 3rd August 2015 11:32 PM
Clio 1.5 dci overheating and leaking water Engines Rayzer88 13 796 17th May 2015 04:07 PM
Mixing gear box oil? Transmissions Rayzer88 14 712 21st April 2015 10:17 PM
Can anyone identify please :) Steering and Suspension Rayzer88 28 1768 18th April 2015 01:41 PM
Fault Codes (Clio Rush dci 65) Electronics Rayzer88 1 494 17th August 2014 08:14 PM
Sponsored Links
Advertisement
Old 31st March 2011   #2
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 1 Time in 1 Post
Re: TDC Sensor problem? amongst others!!
Yes,the crankshaft sensor is the same as the TDC sensor.Technically it is the Crankshaft Positon Sensor,but Renault insist on calling it a TDC Sensor.
It sounds as though the car is misfiring,coil pack failures aren't uncommon.It could also be a faulty/poorly fitted Lambda sensor and a quick emissions test would confirm this.Was the sensor a genuine or aftermarket part?.Is there evidence of any wiring connectors added into the loom to fit the new Lambda sensor?.
__________________
I'd rather push my Alfa than drive a BMW....
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
Old 4th April 2011   #3
Rayzer88
Rayzer88 is
has no status.
Member
Threadstarter
Hi again, the coil pack was changed in may 2009 but im thinking of changing it again as its relatively cheap and easy to do.
Will the MAP sensor have any bearing on how well the car runs? im thinking of changing that too (for the same reason as above!)
Also should the ECU have been reset when the lambda sensor and TDC sensor were changed? If it should and hasn't, is it easy to do and/or will it cause any damage if i reset it?
Thanks!!
Old 4th April 2011   #4
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Do you have a compatible code reader to reset the ECU?
Does the engine start OK when warmed up.
Looks like the garage are on a parts changing mission all at your cost.
Before going any further I suggest you find out what is at fault - no point in throwing good money after bad as they say.
Try these couple of checks.
Remove the spark plugs and check if they are the correct colour and all of equal colour.
Check the air inlet isn't contaminated with engine oil.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 4th April 2011   #5
Rayzer88
Rayzer88 is
has no status.
Member
Threadstarter
The spark plugs are more or less new...fitted about a month ago. Its just bugging me at the moment as i thought that i would feel a noticeable difference in the petrol consumption and how well the car runs..but i seem to have spent £140 for it to feel now different!
Reply
Tags
problem, sensor, tdc
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
