Clio II - creaking sunroof - fixable? - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Bodywork
Notices
Bodywork Paint care, corrossion, body kits, spoilers, skirts etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Bodywork
Reply
Thread Tools Display Modes
Old 9th April 2011   #1
piemanpete
piemanpete is
has no status.
Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi Folks.
Ever since we got this car in June 2010 the sunroof has creaked quite noisily when it's closed. I've greased the tracks and lubricated everything I can see but no difference.
Anyone familiar with this problem and how to fix it? My guess is it's caused by the roof flexing but I have had the same model before and not encountered this problem.
All ideas/suggestions gratefully received.
Thanks again.
Currently in piemanpete's garage:
1999 Clio RXE 1.6 Auto, 2002 Scenic 1.6 Auto
piemanpete is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by piemanpete
99 Clio II - location of a/c control module? Heating & cooling piemanpete 4 1234 3rd May 2011 10:27 AM
02 Scenic 1.6 16v - socket to remove injector... Engines piemanpete 12 3934 30th April 2011 04:04 PM
02 Scenic 1.6 auto - pls help ID engine bay fuses... Electronics piemanpete 0 883 21st April 2011 01:56 PM
How to measure pencil coil resistances Engines glenn7 19 10268 21st April 2011 09:41 AM
Clio II - creaking sunroof - fixable? Bodywork piemanpete 8 4388 9th April 2011 10:05 AM
Sponsored Links
Advertisement
Old 9th April 2011   #2
Silverbacksauce
Silverbacksauce is
a Renault master tech
Member
Silverbacksauce's Avatar
Re: Clio II - creaking sunroof - fixable?
Sunroof creaking is common on clios(and bloody annoying). Noise comes from the thin metal rod in the handle unit that flexes and creates friction on the joining plastic parts. Not much you can do im afraid its just poorly designed. Fit a new hanle or keep you sunroof open!!!
Silverbacksauce is offline   Reply With Quote Quick reply to this message
Old 9th April 2011   #3
piemanpete
piemanpete is
has no status.
Member
Threadstarter
Thanks for the info - can you expand on what you mean by the handle as this is an electric sunroof (sorry, should have mentioned) and has no handle as such?
Old 9th April 2011   #4
Silverbacksauce
Silverbacksauce is
Member
Oops!, Sorry should of asked. In that case its the sides of the sunroof cartridge rubbing against the roof. As the sunroof sits down into the hole in the roof there is approx 3mm of clearance on all sides, if sunroof is not sat centraly and is touching roof at any point the contact creates a rattle/squeeking noise.
From inside, remove the beading trim and pull headling down slightly. You will see approx 16 10mm bolts around the base of sunroof cartridge. If you slacken these bolts you should be able to move the catridge slightly by hand. It just a case of manouvering the cartridge around until it feels central. If you use a torch from inside you will be able to see the movement in relation to the roof hole.
Sometimes it can be trial and error and can take a few attempts but is worth it to stop that bloody annoying noise.
Old 10th April 2011   #5
piemanpete
piemanpete is
has no status.
Member
Threadstarter
That's really helpful - thanks a lot.
I will certainly give it a try.
Cheers
Reply
Tags
clio, creaking, fixable, sunroof
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
