How do you adjust the alternator belt on renault clio? - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 9th April 2011   #1
gtv
gtv is
still here
Diamond member
gtv's Avatar
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi folks we have a late 2001 clio running a 1.5l dci and the belt makes an almighty noise when first started, this is getting bad now and I need to tighten the belt, just had a look and it doesn't look like there is much room there can someone offer some help on how to do this.
many thanks
__________________
Currently in gtv's garage:
Clio Dci 1.5 65bhp
gtv is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by gtv
Laguna int mirror Interiors srafferty 2 902 24th March 2013 01:46 PM
Clio fuses Electronics gtv 4 4946 11th February 2013 06:38 PM
Clio phantom plug Electronics Ralph 1 1189 25th January 2013 07:36 PM
Sponsored Links
Advertisement
Old 9th April 2011   #2
Donald
Donald is
mad
Platinum member
Technical Supremo
Fishing the Sea Champion
Donald's Avatar
Nominated 1 Time in 1 Post
Nominated TOTW/F/M Award(s): 11
Re: How do you adjust the alternator belt on renault clio?
Quote:
many thanks
Iam not 100% sure but i think you have a pre-tensioned pulley fitted to your cars engine so it can't be adjusted?the pre-tensioned pulley itself needs to be replaced as it sounds to me that its lost its tension strength? hence why the belt is slipping and screaming? unless there is oil leaking onto it? the only way to check will be to give the belt an inspection to see of there is any trace of oil on it or any visible oil leak near the belt itself,
Hope this helps Don
Currently in Donald's garage:
2005 Mercedes Benz C200 Classic SE Kompresser & 1998 Fiat Cinquecento Fire Sporting,some may say i could do far better?,i say i could do far worse.
Donald is offline   Reply With Quote Quick reply to this message
Old 10th April 2011   #3
Ralph
Ralph is
Laid back
Platinum member
Ralph's Avatar
Nominated 2 Times in 8 Posts
Nominated TOTW/F/M Award(s): 4
You will have to change the belt and maybe the tensioner, I think you will find it's spring loaded, it needs doing as if it lets go it can take out the cam belt with disastrous results.
__________________
Ralph's 4th law of motion states that any dropped object will immediately hide under a larger object.
If you find a fix for your problem please let us know it will help others.
Ralph Nr Fleetwood NW UK.
Currently in Ralph's garage:
Clio 15 DCi 80, Motomorini 3 1/2, Yamaha MT-07, LMS 5MT 3 1/2 inch Gauge.
Ralph is offline   Reply With Quote Quick reply to this message
Old 10th April 2011   #4
gtv
gtv is
still here
Diamond member
Threadstarter
gtv's Avatar
The belt was new at the beginning of the year and the tensioner was new last year?
Haynes book of lies said it can be adjusted?
Clio Dci 1.5 65bhp
Old 10th April 2011   #5
FoxOkay
FoxOkay is
Universal
Nominated 0 Times in 5 Posts
Nominated TOTW/F/M Award(s): 5
I had to change both the belt and the pully on my 1.9 dci Megane. I know it's not the same engine, but I would imagine you'll have to do the same on yours
Currently in FoxOkay's garage:
2005 BMW 530
FoxOkay is offline   Reply With Quote Quick reply to this message
Reply
Tags
adjust, alternator, belt, clio, renault
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
