2001 scenic electric window motor removal - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 13th April 2011   #1
strayduck
strayduck is
has no status.
Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
i have a problem with a stuck window. it is the drivers window is stuck closed, when i operate the switch the motor is going but wont move. iam hoping it is just the cable as come off somewhere any ideas?
i have seen a detailed explination of how to remove the door panel with pictures on the forum but cannot find it now, if anyone can polnt me in the right direction it would be appreciated
strayduck is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by strayduck
oil leak Engines strayduck 2 416 29th March 2014 08:33 PM
wash/wipe Electronics lancs dave 1 555 28th April 2013 08:06 PM
siezed handbrake Brakes/Hubs Jon67 15 2363 16th March 2013 06:48 PM
electric windows Electronics awburton04 10 2002 10th March 2013 06:25 PM
headlight problems Electronics lancs dave 5 1028 24th November 2012 04:14 PM
Sponsored Links
Advertisement
Old 23rd April 2011   #2
martange
martange is
has no status.
Junior Member
martange's Avatar
Re: 2001 scenic electric window motor removal
I have the exact same problem it sounds.... I joined this forum especially to find any clues on it. Any responses to your post??
Currently in martange's garage:
1993 Renault Scenic 4x4 Privilege
martange is offline   Reply With Quote Quick reply to this message
Old 26th April 2011   #3
strayduck
strayduck is
has no status.
Member
Threadstarter
got it sorted, the cable had jammed in the motor and snapped, not to hard to get out, remove the door card by removing the screw in the door release catch, handle and two at the bottom of the door, ease off the card starting at the bottom, then remove the multi plugs fitted to the window switch, mirror switch and speaker, then remove the inner window sponge, undo the three nuts holding the motor in place the the two bolts holdin the guide rail towrds the outer edge of the door. you now need to drop the windo so you can get to the plastic clip that holds the window in place this removed easier if you twist the white bit not the yellow. it should the come away from the door and remove the multi plug from the motor it took me just on 3 hrs including going to 3 scrapyards to get the part
the best tip i can give is at the scrap yard break the window far easier to remove the retaining clip when you get home connect the multi plug and operate the motor so that the yellow clip is near the bottom of the runner (makes it easier for fitting the glass)
Reply
Tags
electric, motor, removal, scenic, window
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
