2004 Megane Electric Window... Fixed!! (pics) - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 14th April 2011   #1
HeatherJ
HeatherJ is
HeatherJ's Avatar
Nominated 4 Times in 8 Posts
Nominated TOTW/F/M Award(s): 2
Talking 2004 Megane Electric Window... Fixed!! (pics)
First of all a very BIG thank you to peo1987 for this post!
http://www.renaultforums.co.uk/showt...t=81895&page=3 Post #28
It gave me the solution to my broken drivers window! My window had been working fine and then it went up one day and would not work again!! So after searching the forum I found the above post!
So yesterday I took my door apart ! I removed the door trim panel, in order to find the window mechanism. The inside of the door was very damp and the box itself was very wet.
The yellow arrow is the back of the speaker and the red arrow is the actually control box!
Click image for larger version
Name:	Control Box 1.jpg
So I pulled out the wiring plug at the bottom of the box (yellow arrow) but then had to unbolt the motor from the door in order to undo the screw at the red arrow and the one on the opposite side of the box!
Name:	Control Box 2.jpg
In order to fully remove the box, the wires at the top have to be removed. So pull up the black cover, but be careful of the small square seal surrounding this bit and unclip the wires.
Name:	Control Box 3.jpg
Once I had the box out I uncliped the cover (red arrows). There are 5 in all, 2 on each side and 1 on the edge. They are really hard to unclip... some swearing may be necessary.. . Please make sure the seal is kept safe! (yellow arrow)
Name:	Control Box 4.jpg
Once I removed the circuit board it was obvious to see where the water had corroded it! (yellow arrows)
Name:	Control Box 5.jpg
But I then sprayed just the corroded area with WD40 and left it upright to drain off the excess. I then put the box back together covering the seals with silcone. And refitted it to the car!!
Window now works fine . I am so pleased, once again this forum has saved me a lot of money!
If anyone has any questions etc bout this... just ask
Currently in HeatherJ's garage:
Peugeot 407 SW and a Honda Hornet 900cc
HeatherJ is offline   Reply With Quote Quick reply to this message
The Following 18 Users Say Thank You to HeatherJ For This Useful Post:
1980lea (20th March 2012), Allm (26th May 2013), andy smith (6th June 2011), bartles2006 (29th November 2013), boildbeef (7th March 2015), davechelseafan (1st May 2015), daveinsuffolk (23rd September 2014), Dooba (23rd October 2013), Drussell (26th February 2012), engy (16th September 2011), Gallaigirl (9th February 2014), greg wilson (9th August 2011), Lord May (5th January 2014), ncd (7th May 2011), NX51VDR (18th November 2011), Older gent (21st May 2012), Siphiwe (25th March 2013), timthegas (27th June 2014)
5 Lastest Threads by HeatherJ
Have A Good One General Chat coup 7 581 25th December 2015 09:39 AM
Sponsored Links
Advertisement
Old 16th May 2011   #2
HeatherJ
HeatherJ is
Threadstarter
HeatherJ's Avatar
Re: 2004 Megane Electric Window... Fixed!! (pics)
I forgot to add that the windows will need to be reset. Once the window is up, hold the switch up for around 10secs and then wind it all the way down and hold the button down for 10secs!
The Following 5 Users Say Thank You to HeatherJ For This Useful Post:
Anomolouswizard (20th August 2014), chipmonster (20th July 2013), Dooba (23rd October 2013), mparker (13th September 2011), VelSatisfied (16th May 2011)
Old 16th May 2011   #3
costeau
costeau is
has no status, respec!
Diamond dismember
costeau's Avatar
Nominated 0 Times in 1 Post
TOTW/F/M Award(s): 0
Quote:
With what you're telling about the state of the inside of the door as you removed the door card, I do suspect moisture may come back again.
If I were you, I'd take some measures to try and prevent that from happening again.
Wiping away the moisture that's already there, is half the job.
You should also make sure the drain holes and their rubber grommets at the bottom of the door body aren't clogged in any way.
Remove whatever debris you might find there. This is where water is supposed to escape.
If any of it seeps in during heavy rainfall, it should certainly not be splashing about in there,
but instead run out onto the door sills, and from there on to the gutter.
Also, make sure that the window seals along the bottom of the window frame are clean and intact, with no cracks anywhere.
Aside from that, all I can say is that you've done an outstanding job with carrying out and documenting the fix.
Currently in costeau's garage:
2008 Ford Mondeo 2.0 TDCi (Used to have a 2004 Laguna 1.8)
costeau is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to costeau For This Useful Post:
HeatherJ (16th May 2011)
Old 16th May 2011   #4
HeatherJ
HeatherJ is
Threadstarter
HeatherJ's Avatar
Thanks Costeau! I've to do the back door at some point too so I'll double check all those things. Prevention always helps...
Old 8th June 2011   #5
costeau
costeau is
Diamond dismember
costeau's Avatar
Now that you've become a moderator, why not make this thread sticky?
Reply
Tags
2004, electric, fixed, megane, pics, window
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
