master 2.2 dti timing marks on crank please HELP ME - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 17th April 2011   #1
ChrisChristopher
ChrisChristopher is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
A garage did the timing belt with all the timings tools at least 6 times, still not running. When i took it to them it was running but the tensioner was very noisy. Can you please help me?
Hi i have a 52 plate 2.2 dti MASTER and the timing belt and tensioner was very noisy just after some info on how to re time the crank and the cam thanks. I had someone to do it but hers f--k it up, I bought a manual on eBay but on that it tell me that there’s a mark on the crank pulley, on my one there’s no mark on it. Is there any one out there how can HELP
Garage told me that there is it least 4 possible holes in the crank to lock it up, how can i check its TDC
ChrisChristopher is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by ChrisChristopher
HELP, starting problem with vauxhall movano same... Engines ChrisChristopher 4 5780 28th March 2012 08:25 PM
can you please help me with a starting problem on... Engines ChrisChristopher 0 1176 2nd July 2011 12:21 AM
master 2.2 dti timing marks on crank please HELP... Engines simon59 5 5790 17th April 2011 11:26 PM
Sponsored Links
Advertisement
Old 18th April 2011   #2
danthevan
danthevan is
has no status.
Edit
Posts: n/a
Re: master 2.2 dti timing marks on crank please HELP ME
Is it not running or running rough?
Easy way to find tdc is a screwdriver down one of the injector holes. Turn engine by hand and when the screwdriver is furthest out of the hole, you have tdc.
The Following User Says Thank You to For This Useful Post:
VelSatisfied (18th April 2011)
Old 18th April 2011   #3
ChrisChristopher
ChrisChristopher is
has no status.
Junior Member
Threadstarter
the engine is not running
the garage sprayed some think in the air flow meter and then it run very badly and smoked, it would not rev or run without the spray. Diesel is up to the injectors
Thanks Chris
Old 18th April 2011   #4
mickeybo
mickeybo is
has no status.
Platinum member
Nominated 2 Times in 10 Posts
Nominated TOTW/F/M Award(s): 6
I`'m aware renault master has a 2.2 dci engine but is not aware of a 2.2 dti i know the master has a 1.9dti engine can you post your engine code to verify
this Regards Mickeybo
Currently in mickeybo's garage:
1996 Renault Clio 1.9 Diesel.
mickeybo is offline   Reply With Quote Quick reply to this message
Old 18th April 2011   #5
ChrisChristopher
ChrisChristopher is
has no status.
Junior Member
Threadstarter
hi mickeybo
where would i find the engine code? iv got the engine number on the log book ,would that help?
thanks chris
Reply
Tags
crank, dti, marks, master, timing
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
