Scenic ii electronic dashboard resetting - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 19th April 2011   #1
Bigmozzarella
Bigmozzarella is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Has anybody found a solution to this problem:
Our 2004 Scenic ii 1.6 Expression has intermittent problems with the electronic dashboard display.
The clock (time) has reset a number of times.
Now the trip recording & other figures (consumption etc) reset by themselves?
How have you solved it? Any recommendations?
Currently in Bigmozzarella's garage:
Renault Scenic II 1.6 16v
Bigmozzarella is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Bigmozzarella
Scenic ii electronic dashboard resetting Engines zsangyal 4 3091 19th April 2011 05:30 PM
Sponsored Links
Advertisement
Old 19th April 2011   #2
Rentech
Rentech is
has no status.
Diamond member
Nominated 0 Times in 2 Posts
Nominated TOTW/F/M Award(s): 2
Re: Scenic ii electronic dashboard resetting
it is normally a early sign that the dash is about to give up all together, check the radio and interior light fuse just in case, but i feel it is the beginning of the end. BBA remanufacturing can repair.
Currently in Rentech's garage:
Traffic 11/ Scenic Dynamic 106 60plate
Rentech is offline   Reply With Quote Quick reply to this message
Old 20th May 2011   #3
zsangyal
zsangyal is
has no status.
Junior Member
Angry Re: Scenic ii electronic dashboard resetting
Since a week I have the same problem. The trip counter, consumption reset itself randomly, meanwhile the car is in movement, and there is no - audible - engine problem. All test lamp light up - , etc. Radio, internal light works fine during this reset...
Worrying that I can not reproduce it. It happened already by pushing the clutch, or switching to reverse, or simply by passing under a flyover...
Currently in zsangyal's garage:
2003 Renault Scenic 1.4 Caleido and 2004 Renault Grand Senic 1.9dci
zsangyal is offline   Reply With Quote Quick reply to this message
Old 4th December 2011   #4
chrispretorius
chrispretorius is
has no status.
Junior Member
Thumbs up Re: Scenic ii electronic dashboard resetting
I have the same problem after the battery was disconnected for the service , the clock resets every time you start the car could this be a battery problem
Currently in chrispretorius's garage:
Scenic 2 , maxda B1800, Nissan 3.0l sani 4x4, toyota tazz 1600
chrispretorius is offline   Reply With Quote Quick reply to this message
Old 4th December 2011   #5
zsangyal
zsangyal is
has no status.
Junior Member
Mine had been repaired. Renault offered the complete replacement of the instrument panel for 600 euros. However a friend of mine suggested a garage (non-Renault) where they replaced the panel's 12v/5V converter for 80 euros. They said if it goes completely wrong than the repair cost would be double - but still much less than a complete replacement.
Reply
Tags
dashboard, electronic, resetting, scenic, trip computer
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
