Ride Height Level Sensor - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 21st April 2011   #1
MadTogger
MadTogger is
scratching his head
Member
MadTogger's Avatar
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
while under my '04 Laguna Initiale the other day I noticed a small electrical part with an arm coming from it, attached to the chassis rail of the car on the near side, close to the rear axle.
I have now determined that this is the rear ride height level sensor and that it should somehow be attached to the rear axle.
I can see a welded tab on the axle with a hole through it but the sensor seems to be missing a part as the small arm that moves up and down does not seem to reach this tab.
On the end of this arm there likes like what used to be a ball joint, highly corroded.
I have read another thread on this forum where someone has suggested making a repair using modelling parts, this I can do but first I would really appreciate it if one of you Laguna owners out there could please forward me a few photographs of the fully working and in situe sensor so I could easily see what is missing.
Kind regards..,
MT
Currently in MadTogger's garage:
'04 Laguna II 1.9 Dci Initiale
MadTogger is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by MadTogger
Laguna 2 Electric Window Woes Electronics HeatherJ 3 1322 8th November 2011 01:59 PM
Ride Height Level Sensor Electronics MadTogger 6 3312 21st April 2011 04:49 PM
Laguna 2 will not start Electronics MadTogger 1 1471 4th June 2010 02:28 PM
Laguna 2 Initiale Steering Wheel Removal Interiors MadTogger 7 9195 4th June 2010 12:27 PM
Access to rear wiper motor Electronics MadTogger 10 3017 17th February 2010 02:10 PM
Sponsored Links
Advertisement
Old 22nd April 2011   #2
Recycled Scenic
Recycled Scenic is
has no status.
Edit
Posts: n/a
Re: Ride Height Level Sensor
Yes its the ride height level sensor for the headlamps. Mate recently repaired the one his 03 Laguna though IIRC there wasn't anything missing he's coming round tomorrow will see if I can get a photo?
Old 22nd April 2011   #3
MadTogger
MadTogger is
scratching his head
Member
Threadstarter
MadTogger's Avatar
Thanks for the reply, I'll await the photos.
Cheers..,
MT
Old 26th April 2011   #4
Recycled Scenic
Recycled Scenic is
has no status.
Edit
Posts: n/a
Sorry for the delay I have only just been able to take the photos today.
The plastic arm is around 90 - 95mm long and is adjustable with a ball and socket at either end. I would imagine it's around the size they use on radio controled model helicopters. The tie wrap has been put on to stop the lower ball joint poping apart.
The Following User Says Thank You to For This Useful Post:
MadTogger (26th April 2011)
Old 26th April 2011   #5
MadTogger
MadTogger is
scratching his head
Member
Threadstarter
MadTogger's Avatar
Great thanks for the images.
I can see now that I have the arm missing that comes from the axle to the plastic lever arm on the sensor.
From the images and description you gave I can now sort it out.
Once again, thanks a lot for the help.
Kind regards..,
MT
Reply
Tags
height, laguna, level, ride, sensor, xenon
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
