Clio Dashboard and rear light fault - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 23rd April 2011   #1
ERICTGRAAM
ERICTGRAAM is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Clio has a fault with the rear and dashboard lights The main headlights and both front and rear fog lights work but the rear lights and dashboard lights dont Tried checking the fuses light cluster and buls with no success.
ERICTGRAAM is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by ERICTGRAAM
Clio Dashboard and rear light fault Engines Lagdti 4 1603 23rd April 2011 10:58 AM
Sponsored Links
Advertisement
Old 23rd April 2011   #2
danthevan
danthevan is
has no status.
Edit
Posts: n/a
Re: Clio Dashboard and rear light fault
Not sure about the setup on renaults, but that would say to me that the switch is knackered.
Old 23rd April 2011   #3
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 1 Time in 1 Post
Quote:
Hello and welcome to the forum.
What age Clio is it?.
__________________
I'd rather push my Alfa than drive a BMW....
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
Old 23rd April 2011   #4
ERICTGRAAM
ERICTGRAAM is
has no status.
Junior Member
Threadstarter
its a2004 model
Old 23rd April 2011   #5
Lagdti
Lagdti is
Veteran Member
Technical Supremo
Lagdti's Avatar
If you are 100% sure you have checked ALL the fues,then you will need to try and determine exactly where the feed to the lights dissapears.It could be a faulty UCH unit,but these are expensive and need specialist programming when replaced,so a little more investigation work is most definately worth doing.
If you have a test light or multimeter check that you have power to the switch,the fuse etc and go from there.
Reply
Tags
clio, dashboard, fault, light, rear
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
