Drive shaft getting hot - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 23rd April 2011   #1
martynchappell
martynchappell is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi, I have a renault scenic 2002 1400cc 16 valve.My problem is, after the car has been standing for a while everything seems ok but after driving a few miles when everything is warmed up as the car is going along there appears a kind of knocking sound on the front drivers side and there is a kind of dry springy sound after going over bumps or uneven road surfaces that sounds as if the shock absorber is dry. After having it checked there wasnt anything visible that could be found but the drive shaft on the drivers side was hotter than it should be. Does anyone have any ideas what this could be?
Currently in martynchappell's garage:
Renault scenic
martynchappell is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by martynchappell
Drive shaft getting hot Engines martynchappell 4 995 23rd April 2011 11:49 AM
Sponsored Links
Advertisement
Old 23rd April 2011   #2
danthevan
danthevan is
has no status.
Edit
Posts: n/a
Re: Drive shaft getting hot
How hot should the driveshaft be ?
First guess on the driveshaft is probably no grease in the cv joints. Could possibly be the cause of the noise too.
More likely culprit for the noise over bumps is either anti rollbar drop links, or top strut bearings
Old 23rd April 2011   #3
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 1 Time in 1 Post
Quote:
Hello and welcome to the forum.
It would definately be worth pulling the gaiter off of the offside outer CV gaiter and seeing if theres any signs of water ingress or that the joint has dried out at all.Does the gaiter look orginal or has it been replaced at some stage?.
Does the noise get any worse if you pull away with the car on a full lock either way?.
__________________
I'd rather push my Alfa than drive a BMW....
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
Old 23rd April 2011   #4
martynchappell
martynchappell is
has no status.
Junior Member
Threadstarter
Thanks for the reply, there is plenty of grease in the joints and the bearings on the end seem ok. The tip about the anti rollbar is worth me looking into though.... Thanks
Renault scenic
Old 23rd April 2011   #5
martynchappell
martynchappell is
has no status.
Junior Member
Threadstarter
The gaiter has been checked and there is plenty of grease, the car pulls off nice and smoothe and on full lock everything seems perfect.
Renault scenic
Reply
Tags
drive, drive shaft hot, hot, shaft
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
