dephaser setup - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
dephaser setup
Engines
Reply
Thread Tools Display Modes
Old 24th April 2011   #1
alfa
alfa is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Angry dephaser setup
hi, just replaced a cylinder head on an f4r engine now starts and runs badly how do you time the inlet dephaser pulley .ive set mine so that the renault logo is at the top straight (horizontal) ive locked the crank and put a bar across the cam slots .help
Currently in alfa's garage:
2002 renault espace 20.16v
alfa is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by alfa
f4r camshaft seals Engines mickpm 1 941 26th September 2011 12:10 PM
dephaser setup Engines Recycled Scenic 5 5000 24th April 2011 10:39 AM
Sponsored Links
Advertisement
Old 24th April 2011   #2
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 1 Time in 1 Post
Re: dephaser setup
As long as the dephaser is OK it should be locked when you fit it to the cam,so when you time up the cams with the bar all should be well.With the cams locked and the belt off,can you move the dephaser pulley fowards or back at all?.
__________________
I'd rather push my Alfa than drive a BMW....
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
Old 24th April 2011   #3
alfa
alfa is
has no status.
Junior Member
Threadstarter
Re: dephaser setup
hi , what do you mean by it being locked when fitted to cam,dnt think it moves in and out when bolted to cam had belt of 5 times now .what position should the delphaser be in.in relation to head ie where should the renault logo be, thanks for any help in advance stevie
Old 24th April 2011   #4
Recycled Scenic
Recycled Scenic is
has no status.
Edit
Posts: n/a
Re: dephaser setup
Have you removed the dephaser pulley from the inlet cam shaft? It doesn't matter where relationship of the logos are to anything really. Like Lagdti says as long as you have locked the cams together in the setting position all should be okay assuming there is no excessive belt slack between the cam pulleys.
If the dephaser pulley is working correctly it the internal mechanism should be locked so there is no movement in one direction or the other. It's only after the engine is running should the dephaser unlock and allow the inlet cam shaft to advance the inlet timing.
You are using a cam shaft locking tool? in the timing slots in the ends of the cam shafts?
Old 24th April 2011   #5
alfa
alfa is
has no status.
Junior Member
Threadstarter
Re: dephaser setup
yes im using a locking bar on the back of cams and locking crank with pin the cars holding bak and barely pulling like the timing was out or air getting in inlet manifold i do hear the exaust blowing from back of head. so the dephauser pulley can go in any position iv ming set with the renault logo at top in the horizotal position .is this ok with cams locked and pin set in crank. im now wondering if its an air leak causing the poor running (really bad) many thanks stevie
Reply
Tags
dephaser, setup
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
