Re: Espace 2.2 dci how do u fit/reset a Clutch plate
Thanks for your prompt reply, i dont think these clutches are as the standard set-up ie using a clutch mandrel to hold the clutch plate in place central to the pressure plate before attaching to the flywheel.
Its a bit more than that. I did have a look at a manual somewhere that did explain how to do it, but i think you need some type of jig.
Currently in Eddy Teddy's garage: grand espace x 2 2.2 dci's, movano 2.2 dti, master 2.5 dti, audi a6 1.9tdi avant
