Megane boot will not open - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Bodywork
Notices
Bodywork Paint care, corrossion, body kits, spoilers, skirts etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Bodywork
Reply
Thread Tools Display Modes
Old 2nd June 2011   #1
Rachel4498
Rachel4498 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi My meganes boot will not open can anyone advise what to do before i clobber it, its driving me mad
Currently in Rachel4498's garage:
2003 Megane
Rachel4498 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Rachel4498
Megane boot will not open Bodywork ste2rog 6 14852 2nd June 2011 01:34 PM
Sponsored Links
Advertisement
Old 2nd June 2011   #2
Ralph
Ralph is
Laid back
Platinum member
Ralph's Avatar
Nominated 2 Times in 8 Posts
Nominated TOTW/F/M Award(s): 4
Re: Megane boot will not open
Crawl in the book with torch, look were the catch is and you should see a small slot, with a small flat screw driver through that and moving it up or down cant remember which you should be able to open it, you will then have to take the back off the lid and find the problem, could be water in the works just need some wd40 or some such or a burnt out motor, if its the motor you may have to buy the completer lock if you cant find a motor you may find one on Evil Bay or a model shop depending on the motor fitted.
__________________
Ralph's 4th law of motion states that any dropped object will immediately hide under a larger object.
If you find a fix for your problem please let us know it will help others.
Ralph Nr Fleetwood NW UK.
Currently in Ralph's garage:
Clio 15 DCi 80, Motomorini 3 1/2, Yamaha MT-07, LMS 5MT 3 1/2 inch Gauge.
Ralph is offline   Reply With Quote Quick reply to this message
Old 2nd June 2011   #3
HeatherJ
HeatherJ is
HeatherJ's Avatar
Nominated 4 Times in 8 Posts
Nominated TOTW/F/M Award(s): 2
Mine wouldn't open because the switch that you use to open the boot was broken. Water tends to get into the switches and corrode them. I pulled mine out and replaced it with a new one and now my boot opens fine.
Currently in HeatherJ's garage:
Peugeot 407 SW and a Honda Hornet 900cc
HeatherJ is offline   Reply With Quote Quick reply to this message
Old 2nd June 2011   #4
costeau
costeau is
has no status, respec!
Diamond dismember
costeau's Avatar
Nominated 0 Times in 1 Post
Water ingress seems to be common with the Megane.
Leave the car a few hours in a dry spot, and try again.
Once you can open it, unscrew the inside panel of the bootlid, so that you can access the lock mechanism.
I'd recommend not using WD40 for the corrosion cleanup, but instead use contact cleaner (which you can get from the likes of Maplin).
Once corrosion and stuff are cleaned up, plug it back together, and seal off the connector with a bit of non-acidic vaseline.
Currently in costeau's garage:
2008 Ford Mondeo 2.0 TDCi (Used to have a 2004 Laguna 1.8)
costeau is offline   Reply With Quote Quick reply to this message
Old 6th June 2011   #5
Rachel4498
Rachel4498 is
has no status.
Junior Member
Threadstarter
Thank you for your reply it will not be being repaired as its now ben damaged beyond repair the handbrake failed parked up on a hill, very upset so being scrapped
2003 Megane
Reply
Tags
boot, bott, megane, open
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
