2004 Megane erratic idle & over revving - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 18th June 2011   #1
bloobloo
bloobloo is
wondering about things
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi everyone. As the title says I have a problem with my wifes Megane over revving and erratic idle. I have took off the throttle boy and given it a clean, but noticed that the throttle itself doesnt close fully. How are these throttle bodies meant to be? I have put it all back together and it still has the same problem, but also noticed that if i manually turn the throttle with the tip of a screwdriver i can stop the erratic idle. It seems as if the motor on the opposite side isn't actually closing the throttle enough. Will this be the problem or is that how it is meant to be?
Kind regards
Mike
Currently in bloobloo's garage:
Renault Megane II, Mitsubishi Pajero, Renault Clio II
bloobloo is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by bloobloo
2004 Megane erratic idle & over revving Engines hunter20 11 15461 18th June 2011 08:59 PM
Clio II (y reg) hazard lights problem Electronics bloobloo 2 2125 15th December 2010 03:20 AM
Sponsored Links
Advertisement
Old 18th June 2011   #2
ourcar
ourcar is
has no status.
Edit
Posts: n/a
Re: 2004 Megane erratic idle & over revving
I'd imagine it should not completely close or you would get no air to the TB.
If it is over revving, then it is getting too much air, check that there are no leaks prior to the TB.
It is possible that your MAP sensor is busted, worth getting checked.
Old 21st June 2011   #3
bloobloo
bloobloo is
Junior Member
Threadstarter
Hi, I have done a search over the last few days, looking for info on why my Megane is over revving and surging at idle.
Up to now I have found various posts but none that are the same prblem as mine, or that have been solved.
When the car is started, the car idles around 1600 - 1800 rpm, no misfires or any other problems. Once driven the car still idles at high revs, but also surges from 1000rpm upto 2800rpm.
So far I have removed and cleaned the throttle body, checked and improved the throttle body to manifold seal, tried a different MAP sensor, tried a different set of coil packs, checked for any other air leaks on the intake system. All to no avail.
I have ordered an ELM 327 diagnostics able and software to check any fault codes and that should arrive tomorrow, my galletto arrived today!
Any help greatly appreciated
Forgot to mention its a 2004 1.4 16v megane, 54,000 miles
Mike
bloobloo Posts: 2 Joined: Sat Jun 18, 2011 4:50 pm
Old 21st June 2011   #4
ourcar
ourcar is
has no status.
Edit
Posts: n/a
Did you replace the seals that go between the upper and lower inlet manifold?
Old 21st June 2011   #5
bloobloo
bloobloo is
Junior Member
Threadstarter
No, I took out the seals and gave them a good clean. The first time i took it apart I used a gasket sealant but that made no improvement. I then went to the breakers yard and got another inlet manifold for £4.00 just in case the other one was cracked etc. I then took off the 1st inlet manifold, scraped and cleaned all the other gasket sealant off the lower inlet and replaced the top manifold. I will order new seals tomorrow and try that.
Reply
Tags
2004, erratic, idle, megane, revving
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
