Kangoo 1.4 not ticking over when cold ? - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 22nd June 2011   #1
thomas3
thomas3 is
has no status.
Diamond member
Nominated 0 Times in 1 Post
TOTW/F/M Award(s): 0
Hi there
My kangoo 1.4 petrol x reg has developed an annoying problem, starting up from cold it will not idle untill it has warmed up to temp. Are there any sensors that could be playing up. Ive changed all the filters and spark plugs but no joy and on the odd occasion when pulling up at a junction it will cut out as you have one foot on the clutch and one on the brake. Any one got any ideas what to look out for.
Thanks Pj
Currently in thomas3's garage:
KANGOO 1.4 2001
thomas3 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by thomas3
Kangoo 1.4 2001 heater fan not working. Heating & cooling thomas3 6 5104 28th October 2011 05:17 PM
Kangoo 1.4 not ticking over when cold ? Engines Recycled Scenic 4 2031 22nd June 2011 10:11 PM
Renault Kangoo Immobilizer fix Electronics thomas3 0 1814 27th January 2011 09:16 PM
fuel tank sender unit removal Electronics madnoel10 9 7239 15th October 2007 11:56 AM
Kangoo strange noise help Electronics Donald 3 1256 14th October 2007 08:42 PM
Sponsored Links
Advertisement
Old 22nd June 2011   #2
Recycled Scenic
Recycled Scenic is
has no status.
Edit
Posts: n/a
Re: Kangoo 1.4 not ticking over when cold ?
Quote:
Originally Posted by thomas3 View Post
Hi there
Thanks Pj
It could be the temperature sender unit in the thermostat housing.
The Following User Says Thank You to For This Useful Post:
thomas3 (23rd June 2011)
Old 23rd June 2011   #3
thomas3
thomas3 is
has no status.
Diamond member
Threadstarter
Thaks for the quick reply I will have a look and report back.
Pj
KANGOO 1.4 2001
Old 27th June 2011   #4
thomas3
thomas3 is
has no status.
Diamond member
Threadstarter
Just an update ive fixed the idling problem on my kangoo 1.4. It turned out to be a gummed up idle control valve on the back of the throttle body. Just strip out the air filter housing and dissconnect the wiring and you can remove the 2 torx screws holding it in place. I cleaned it out with carb cleaner and cloths then let it to dry before refitting it. Cured the problem straight away and saved having to pay 70 quid for a new one.
Thomas
KANGOO 1.4 2001
Old 27th June 2011   #5
Recycled Scenic
Recycled Scenic is
has no status.
Edit
Posts: n/a
Thumbs up Re: Kangoo 1.4 not ticking over when cold ?
Glad to hear you got it sorted
Reply
Tags
cold, kangoo, ticking
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
