hissing sound behind glove box - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Heating & cooling
Notices
Heating & cooling A place to discuss heating, air-con etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Heating & cooling
Reply
Thread Tools Display Modes
Old 1st July 2011   #1
aligig
aligig is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Question hissing sound behind glove box
can anyone help me i have a scenic 2003 1.4 , every so often there is a loud hissing sound , which sounds like its coming from the glove box . then water starts to drip into the foot well , the car steams up and the fan becomes alot louder and you can feel a vibration in the steering wheel . it seems to do it more when it rains . any ideas please .
aligig is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by aligig
hissing sound behind glove box Heating & cooling aligig 4 1725 1st July 2011 08:01 PM
Sponsored Links
Advertisement
Old 1st July 2011   #2
Recycled Scenic
Recycled Scenic is
has no status.
Edit
Posts: n/a
Re: hissing sound behind glove box
Hello and welcome to the forum
Does the car over heat and does the coolant need toping up?
Sounds very much like the heater matrix is leaking?
Old 1st July 2011   #3
aligig
aligig is
has no status.
Junior Member
Threadstarter
no it never over heats and the coolant level has not gone down
Old 1st July 2011   #4
Recycled Scenic
Recycled Scenic is
has no status.
Edit
Posts: n/a
The air intake on your Scenic is underneath the plastic cover at the bottom of the wind screen on the passengers side of the car.
There is a channel that runs from one side of the car to the other and there are 2 rubber flaps on either side of the car to allow the water that runs down the windscreen and gathers in the channel to run out they have either become stuck or have debris in front of them. The air intake scoop lip isn't very high above the drain channel so when there is heavy rain or you park with the drivers side wheels on the pavement the water isn't draining away quickly enough and the excess can get into the air intake and heater fan.
As far as the hissing noise goes I imagine it must the heater fan spraying the water around? and the vibration is being caused by the water putting the fan out of balance.
I would get the drain channel flaps cleaned.
You will have to remove both wind screen wiper arms and the several retaining torx head screws to remove the 2 plastic covers. There are around 5 white plastic clips behind the covers which can get broken if not careful.
Old 2nd July 2011   #5
aligig
aligig is
has no status.
Junior Member
Threadstarter
Smile Re: hissing sound behind glove box
thanks i will try that tomorrow
Reply
Tags
box, glove, hissing, sound
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
