Renault Laguna 2 - Ball Joint Replacement - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Read our Articles » Laguna
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Laguna
Reply
Thread Tools Display Modes
Old 3rd July 2011   #1
srafferty
srafferty is
driving
Diamond member
srafferty's Avatar
Nominated 1 Time in 1 Post
TOTW/F/M Award(s): 0
Lightbulb Renault Laguna 2 - Ball Joint Replacement
Tools
19mm Socket / Wheel Brace
Jack & Axel Stands
17mm Socket
19mm Open Spanner
Grinder
2Kg Hammer & Chisel
Ball Joint Separator (Wedge)
21mm Socket
24mm spanner
Torque Wrench.
Removal
1. Using 19mm Socket or Wheel Brace slacken wheel nuts.
2. Jack up car and secure on axel stands
3. Remove wheel
4. Using a 17mm Socket, disconnect the track rod end from the hub.
5. Optional (just to get it out of the way) - Using a 19mm spanner slacken the lock nut on the track rod end 1/2 a turn and remove the latter by simply unscrewing.
6. Remove ABS sensor cable
7. Using a 24mm spanner remove the nut at the top of the ball joint (found this quite stiff with no room to put a socket on it)
8. If the ball joint to be removed was a replacement, you're laughing - Using 17mm socket and spanner remove nuts and bolts
If the ball joint to be removed is original it will be riveted on. This is the fun part took me almost two hours.
9. Using a cutting disc grind off the heads of the rivets at the bottom of the ball joint.
10. Using the chisel and wedge remove the ball joint from wishbone (lots of banging required - those rivets are very, very tight - took me ages).
11. :loser: Very Important - Using your grinder again grind along the side of the rivet to make it thinner and easier to go through the wishbone so that when you hammer them through, and they tend to flatten more, they don't end up just getting even harder to remove.
12. Hammer the rivets out.
Fitting
1. Using the 3 nuts and bolts supplied, fit the new ball joint to the wishbone (I torqued these to 60Nm).
2. As someone else posted, it's easier to remove the hub carrier to fit the new ball joint. Using a 21mm Socket remove the two bolts holding the hub carrier to the strut.
3. Raise the hub carrier into place on the ball joint.
4. Refit the hub carries to the strut using original 21mm bolts and torque to 180Nm
5. Fit and tighten the 24mm nut on the ball joint. This is supposed to be torqued to 110Nm. How in god's name you're supposed to do this without having taken out the drive, I have no idea.
6. Replace ABS cable
7. Replace track rod end remembering you slackened the lock nut 1/2 a turn.
8. Attach Track Rod End to Hub using 17mm nut and torque to 37Nm
9. Refit wheel
10. Lower car
11. Torque wheel nuts to 105Nm
Currently in srafferty's garage:
A Push Bike
srafferty is offline   Reply With Quote Quick reply to this message
The Following 10 Users Say Thank You to srafferty For This Useful Post:
Elkongen (4th January 2015), fieldmaster (18th February 2012), liamthecoder (17th February 2012), maa1506 (10th July 2011), mayates76 (15th March 2012), multibob (28th February 2012), N7Qauto (14th July 2011), primera (9th August 2011), RobLagunaII (8th August 2011), stella1artois (20th October 2011)
5 Lastest Threads by srafferty
Airbag warning Electronics srafferty 4 433 14th July 2015 11:28 AM
Keyless Entry Electronics srafferty 9 1106 11th March 2015 04:23 PM
Curiousity Wheels & tyres srafferty 11 1551 29th July 2012 11:16 PM
Airbag Light Electronics srafferty 0 663 28th July 2012 05:09 PM
F9Q Timing Belt Change Engines srafferty 3 2220 10th April 2012 09:53 AM
Sponsored Links
Advertisement
Old 24th September 2011   #2
Spaceman Spiff
Spaceman Spiff is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
Thumbs up Re: Renault Laguna 2 - Ball Joint Replacement
Quote:
Originally Posted by srafferty View Post
Tools
Jack & Axel Stands
17mm Socket
19mm Open Spanner
Grinder
2Kg Hammer & Chisel
21mm Socket
24mm spanner
Torque Wrench.
Removal
3. Remove wheel
Fitting
9. Refit wheel
10. Lower car
Just done this job on the nearside front, it is a fiddly job but I found that it wasn't necessary to remove or disconnect the track rod at all, I turned the steering about half lock to the left and when the lower arm is pushed down just swing the leg towards the back of the car, you will need to disconnect the drop link to do this though. I found that drilling the rivets out from above was a quicker and easier option than using the grinder. These are just my thought's on the job and by no means the right/wrong way of doing it.
Thanks for the Original post though
Carl
Currently in Spaceman Spiff's garage:
2003 Laguna II, 2.2 Dci, Initiale estate
Spaceman Spiff is offline   Reply With Quote Quick reply to this message
The Following 3 Users Say Thank You to Spaceman Spiff For This Useful Post:
bjbrownie (2nd October 2011), mayates76 (3rd February 2012), srafferty (19th August 2014)
Old 14th October 2011
PedroDepue
This message has been deleted by Devils Laguna.
Old 17th February 2012   #3
liamthecoder
liamthecoder is
has no status.
Junior Member
Just about to do this on my laguna RTsport, Great Tutorial
Currently in liamthecoder's garage:
1997 Reault Laguna 1.8 RT Sport, Laguna 1.8 16v Estate (2002)
liamthecoder is offline   Reply With Quote Quick reply to this message
Old 19th February 2012   #4
colin39
colin39 is
has no status.
Diamond member
colin39's Avatar
no grinder so i opted for the gas axe done them in no time.
Currently in colin39's garage:
2003 Renault Laguna II 1.9dCi
colin39 is offline   Reply With Quote Quick reply to this message
Old 28th February 2012   #5
tomshine
tomshine is
has no status.
Member
tomshine's Avatar
I followed a similar guide and its can be difficult getting the rivits out to replace the balljoints refitting is much easier. But within six months notice that the rubber bushing on wishbone where worn. Wishbone comes with balljoint so would have been better to have replace the lot rather than doing the job twice.
Currently in tomshine's garage:
2001 Renault Laguna II 1.9dCi - 2001 Jeep Grand Cherokee Diesel - Megane 1.4 16V
tomshine is offline   Reply With Quote Quick reply to this message
Reply
Tags
ball, joint, laguna, renault, replacement
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
