Renault Megane 2 - Running Fault/Codes - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 28th July 2011   #1
marius01
marius01 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Exclamation Renault Megane 2 - Running Fault/Codes
Hello Fellow Renault lovers.
Newbie
I hope some one can assist me with a couple of issues i have with my new secondhand Renualt, which is driving me Crazy.
took the vehicle to Renualt and they gave me the following feedback after the vehicle started giving me problems.
P2502 - CHANGING SYSTEM VOLTAGE
P0325 - KNOCK SENSOR 1 CIRCUIT (BANK 1
UPSTREAM 02 SENSOR CIRCUIT
P0340 CAMSHAFT POSITION SENSOR "A" C
the issue with the car is as follows, when the vehicle is cold, it runs perfect, with the exeption of a wizzzzzz sound coming from the engine (and the car does not have a turbo)- i think this might be the dephaser pulley, but the car has power at this stage, until the heat reaches the normal running temp. then the issues start, the vehicle will just suddenly loose almost all power, if you push the clutch in and press down on the accelerator the car will rev. but if you drop the clutch again no power.
i have replaced the camshaft sensor myself- actualy very easy todo.
also replaced the coil pack and plugs with brand new ones.
tested it last night again after the sensor was replaced, and the car does the same as mentioned above.
could it be that the upstream sensor that gives the issue ?? when the car reach a certain heat it malfuntion ??
i would be so thankful if any one can assist, as this is driving me crazy
Currently in marius01's garage:
2005 Renault Megane 2 1.6 16v
marius01 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by marius01
Renault Megane 2 - Running Fault/Codes Engines marius01 11 8438 28th July 2011 08:45 AM
Sponsored Links
Advertisement
Old 28th July 2011   #2
scatz
scatz is
gonna try and spend more time on RF this year
Platinum member
scatz's Avatar
Nominated 0 Times in 4 Posts
Nominated TOTW/F/M Award(s): 5
Re: Megane Engine issues
You don't mention whether you have tested or replaced the o2 sensor! A failed sensor can cause hesitation/surging in the power!
__________________
Currently in scatz's garage:
2004 Subaru Legacy GT Spec B, a 2013 2.0 TDCi Titanium X Sport S-Max and a 2001 Honda NSR125R
scatz is offline   Reply With Quote Quick reply to this message
Old 28th July 2011   #3
marius01
marius01 is
has no status.
Junior Member
Threadstarter
Quote:
No i havent replaced this as yet planning to replace it ASAP, but could the upstream sensor be the problem, causing the issue of no power ?
Old 28th July 2011   #4
scatz
scatz is
Platinum member
scatz's Avatar
One sensor failing can be a catalyst for others so it's not inconceivable that it's part of a wider problem! If duff information is being sent to the ECU then it could be trying to compensate but incorrectly.......it's all wizardry to me to be honest!
A failed o2 sensor can cause a rich fuel mix which, in turn, can knacker the catalytic converter, this could also cause a loss in power. You see, there are many reasons and you need to first start by curing the codes so to speak. You also need to ensure the codes are cleared once you believe everything is rectified.
Old 28th July 2011   #5
marius01
marius01 is
has no status.
Junior Member
Threadstarter
thank you for the help sofar :-)
how do i test o2 sensor ?
might a damaged dephaser pulley also cause the vehicle to lose power when vehicle is hot ?
as the whole issue is only when the vehicle reach running temp. when the issues start - i am not sure how the Temp. of the vehicle can affect a sensor ?
Reply
Tags
engine, fault or codes, issues, megane, renault, running
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
