Poorly Renault Kangoo. Fuel pump or headgasket ? - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 4th August 2011   #1
Stevieboy118
Stevieboy118 is
on a mission from Glod.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Unhappy Poorly Renault Kangoo. Fuel pump or headgasket ?
Spare car from the wifes work is poorly. Kangoo 1.9D, Lucas pump.
When driving it has almost no power (i had to find a flat route from where it was to our place so i could have a look at it!), when stopped at lights there are clouds of white smoke billowing from the exhaust, bad enough the people were doing their windows up to stop the smoke from going into their cars. The engine knocks heavily if you let the revs build up.
On first inspection, the water bottle is empty, the alternator is loose (the pivot bolt didn't have a nut on it, it was being held in line with the aux belt tension) and the timing seems to be way out (took details from autodata and the timing marks don't point to where they should (badly fitted belt maybe?)
Fill the water bottle to just over the max mark.
Pulleys marked up, belt off, timing set to "normal", belt back on, doesn't run, set back to original settings, doesn't run...
Boost pack and jump leads and after lots of cranking, it starts, lots of smoke, knocking, won't rev, etc.
Change TDC sensor. Still hard to start, smoke, etc.
Plug in my code reader, no power to the OBD socket. Odd. Engine warning light doesn't come on either ...
Strip the clocks out, some *** has chiselled the LED off the board so the engine won't flash up .....
Try moving the pump timing back and forwards 1 or 2 teeth in either direction but it will only start in the "original" position (which doesn't match up with the usual timing markings on the cam belt)
I notice that the pump pulley is twisted, looks like a wobbly wheel trim when the engine runs, has somebody had the forced the pulley off and damaged the pump internals? Is the Lucas Epic pump on a keyway, could they have refitted the pulley "wrong"?
After running the engine for about 2 minutes in total (too embarrassed by the smoke and smell to run it any longer), the water bottle is empty again.
It takes about 10 seconds of cranking to get it to start.
Soooo, is it a duff fuel pump, Lucas Epic aren't the best of things when they're working anyway, and/or is it the head gasket? The water level dropped 6 inches in a couple of minutes and the exhaust is putting out LOTS of white smoke.
Any ideas? (my preferred option is to weigh the damn thing in)
Stevieboy118 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Stevieboy118
Poorly Renault Kangoo. Fuel pump or headgasket ? Engines dannyboy0001 6 2691 4th August 2011 05:47 PM
Sponsored Links
Advertisement
Old 4th August 2011   #2
Ralph
Ralph is
Laid back
Platinum member
Ralph's Avatar
Nominated 2 Times in 8 Posts
Nominated TOTW/F/M Award(s): 4
Re: Poorly Renault Kangoo. Fuel pump or headgasket ?
Maybe they removed the fuse or power lead to the OBD connector as well, for what its some years back we had a tractor come in it had a Lucas pump, what had happened was they had left it parked outside and the engine had partly filled with water down the exhaust, when they tried to start it they got a hydraulic lock, we got the water out but it would not start the pump shaft was twisted, maybe with the cylinders hydraulically locked it puts back pressure on the pump through the fuel system and bends the shaft, I must admit I find it hard to believe and always thought it was just one of those things but your post made me think.
__________________
Ralph's 4th law of motion states that any dropped object will immediately hide under a larger object.
If you find a fix for your problem please let us know it will help others.
Ralph Nr Fleetwood NW UK.
Currently in Ralph's garage:
Clio 15 DCi 80, Motomorini 3 1/2, Yamaha MT-07, LMS 5MT 3 1/2 inch Gauge.
Ralph is online now   Reply With Quote Quick reply to this message
Old 5th August 2011   #3
Prickleypear
Prickleypear is
the fruit of a cactus from South Africa
La sola lupo
Prickleypear's Avatar
Nominated 1 Time in 1 Post
The white smoke, power loss and the smell sounds like pump timing could be to earlly, but it may be that water is present in the combustion chamber which may also cause smoke and power loss
Currently in Prickleypear's garage:
'85 Renault 11TS, '97 Megane 2lt 8v RXE, '96 Extra 1.9d, '95 Merceds C220, '64 Fordson Supermajor Tractor
Prickleypear is offline   Reply With Quote Quick reply to this message
Old 5th August 2011   #4
Stevieboy118
Stevieboy118 is
Junior Member
Threadstarter
Well the pump is the electric Lucas Epic, so there's no fine tuning available there.
It is looking like water ingress.
Bugger.
Old 5th August 2011   #5
Stevieboy118
Stevieboy118 is
Junior Member
Threadstarter
Been out to see if it using water (top the tank up again) and i've flattened the boost pack trying to start the damn thing.
Reply
Tags
fuel, headgasket, kangoo, poorly, pump, renault
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
