Laguna II 1.9dCi Engine wont start - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 15th August 2011   #1
Chooky1
Chooky1 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi All, wondering if anyone can help. Got a 53 plate laguna, i was carrying out a service on the car and dropped my socket across the terminal of the alternator +ve to the engine, resulting in with many sparks, now when i try to star the car nothing happens just a clicking noise from under the bonnet.
Not sure if some sort of relay or something has blown i have check fuses and moved about relays (apart from one black one), tried a new battery, and i've run out of ideas, please help
Cheers
colin
Currently in Chooky1's garage:
2003 Renault Laguna II 1.9dCi
Chooky1 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Chooky1
Laguna II 1.9dCi Engine wont start Engines Recycled Scenic 5 1244 15th August 2011 12:19 AM
Sponsored Links
Advertisement
Old 15th August 2011   #2
Recycled Scenic
Recycled Scenic is
has no status.
Edit
Posts: n/a
Re: Laguna II 1.9dCi Engine wont start
Hello and welcome to the forum
You have checked the large 60/70 amp fuses ?
Old 16th August 2011   #3
Chooky1
Chooky1 is
has no status.
Junior Member
Threadstarter
I have checked all fuses. I changed the battery over but still no luck.
It's going to the garage tomorrow as I've ran out of ideas so I'll put up the results soon as.
Old 16th August 2011   #4
Recycled Scenic
Recycled Scenic is
has no status.
Edit
Posts: n/a
It will be interesting to find out the cause of the problem.
Old 18th August 2011   #5
Chooky1
Chooky1 is
has no status.
Junior Member
Threadstarter
Cars fixed!
Fault was a fused link on the battery, the larger red cable out of the two, feel a alittle silly that i never spotted it.
but i know for next time
renualt was £400 for a new wiring loom, the guy at the garage has recrimped the cable with out the link.
Does anyone know where i could find a replacement with out the cost ?
Reply
Tags
19dci, engine, laguna, start
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
