scenic not starting. - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 26th August 2011   #1
pjbude
pjbude is
has no status.
Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
hello.
about 3 weeks ago i tried to start the car and it took ages. just kept turning over but not starting. it did after about 10 mins and didnt do it again until monday of this week. now its everytime i try to start the car. i read a few posts on here that seem to point to the immobiliser being the problem. i have a scenic 2000 w-reg 1.6 16v mk1 facelift. it has the chip in the key and transponder type of immobiliser. have tried the locking and unlocking and taking out the key and putting it back in and this works sometimes but not everytime. have also tried using the spare key to check if the key i was using was faulty.
what else could have gone wrong with it? do the ignition barrel transponders ever break? and how do i check if it is actually the immobiliser and not another fault?
Currently in pjbude's garage:
2001 Laguna II 1.9 DCI Tourer
pjbude is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by pjbude
laguna 2 radio steering control wiring. Electronics pjbude 0 903 8th June 2013 03:15 PM
warning lights Brakes/Hubs pjbude 0 579 31st May 2013 05:46 PM
Laguna estate aerial Engines Lagdti 3 960 9th May 2013 07:14 PM
Laguna no power when cold Engines pjbude 1 871 9th May 2013 07:09 PM
Laguna tourer steering. Engines pjbude 2 718 1st May 2013 07:51 PM
Sponsored Links
Advertisement
Old 26th August 2011   #2
OLD 2.0 SCENIC
OLD 2.0 SCENIC is
has no status.
Diamond member
Re: scenic not starting.
If the immobiliser works properly the red light on the dash slows down or stops (can't remember which) just after turning the ignition on.
Maybe its worth checking your top dead center sensor as they can cause starting problems and its easy to get at and clean there will be a picture if you search TDC sensor, I keep meaning to look at mine!
Currently in OLD 2.0 SCENIC's garage:
1999 MEGANE SCENIC 2.0 RT
OLD 2.0 SCENIC is offline   Reply With Quote Quick reply to this message
Old 27th August 2011   #3
Phil C
Phil C is
Argh! Where's the spanner?
Platinum member
Phil C's Avatar
Nominated 0 Times in 3 Posts
To add I don't know if the scenic tdc sensor is in the same place as the Laguna but if it is, it'll be on the gearbox housing underneath the undertray
Currently in Phil C's garage:
Ford Fiesta mk4
Phil C is offline   Reply With Quote Quick reply to this message
Old 27th August 2011   #4
pjbude
pjbude is
has no status.
Member
Threadstarter
how do you check/clean the tdc?
Old 27th August 2011   #5
Phil C
Phil C is
Platinum member
Phil C's Avatar
Unbolt then unplug it, give a small squirt of wd40 and a quick wipe
Ford Fiesta mk4
Reply
Tags
scenic, starting
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
