My 52 reg 2.0 16v renault clio sport 172 cup isent running rite helpp!! - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 30th August 2011   #1
tonyp123
tonyp123 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Unhappy My 52 reg 2.0 16v renault clio sport 172 cup isent running rite helpp!!
I have a 52 reg 2.0 16v clio sport 172 cup and its not running rite the engine sounds awfull when ticking over and the revs drop very low i have to rev it hard to bring revs back up but then they drop again.
I have replaced the map sensor cleaned out the throttle body, has any1 got any ideas i dont know where to locate anymore sensors on the car as its quite hard to find answers for my model so any help/advice wud be much appreciated, Thankyou
tonyp123 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by tonyp123
My 52 reg 2.0 16v renault clio sport 172 cup... Engines madnoel10 10 6869 30th August 2011 09:20 PM
Sponsored Links
Advertisement
Old 30th August 2011   #2
cockers
cockers is
probably fixing a renault.
Diamond member
Nominated 1 Time in 1 Post
Re: My 52 reg 2.0 16v renault clio sport 172 cup isent running rite helpp!!
does the engine sound like a diesel when hot ? if so sounds like dephaser pully needs replacing.
also have you changed the spark plugs ? these are common fault as is coil.
But before just changing parts , get it diagnosed correctly , will save you money in the long run.
cockers is offline   Reply With Quote Quick reply to this message
Old 30th August 2011   #3
Recycled Scenic
Recycled Scenic is
has no status.
Edit
Posts: n/a
Hello and welcome to the forum
As cockers has said if the engine sounds like a diesel when warm the it's probably the dephaser pulley.
Pencil coils can fail on these engines for a pass time.
Old 31st August 2011   #4
tonyp123
tonyp123 is
has no status.
Junior Member
Threadstarter
Thanks for your advise i will have a look at it in the morning, And update you on the progress, Hopefully it will be what you advise, Thanks again
Last edited by tonyp123; 31st August 2011 at 02:51 AM. Reason: never finished post
Old 31st August 2011   #5
tonyp123
tonyp123 is
has no status.
Junior Member
Threadstarter
Just a question about the throttle body wheni took it off to clean it, it was abit open not sure if its supposedd to be like this or completly closed ?? Any ideas
Reply
Tags
16v, 172, 2.0 16v, clio, cup, helpp, isent, reg, renault, rite, running, sport
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
