Renault Scenic Cooling fan - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 1st September 2011   #1
gwarland
gwarland is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I have a 52 plate 1.4 Renault Scenic.
The cooling fan is not kicking in wwhen it gets too hot and my water is boiling!
Ive checked everything I can find,
the fan works when connected directly to the battery
All fuses are ok
Ive checked the relay that the fan is connected to which works
the top and bottom pipes on the radiator are hot
I assume it is a faulty thermstat but am struggling to find them, ive been told there are 2 on the scenic, one controls water flow and one controls the fan.
I assume the one that contols water flow is the big one on the radiator, the other one I am unable to find.
Please can anyone help? I cannot think of anything else to try!
Gav
Currently in gwarland's garage:
2002 Renault Scenic 1.4 expression+
gwarland is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by gwarland
Scenic starting problems, imobiliser light not on Engines gwarland 0 424 25th January 2013 08:28 AM
Renault Scenic Cooling fan Engines bugsb 3 1838 1st September 2011 07:19 AM
Sponsored Links
Advertisement
Old 1st September 2011   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Re: Renault Scenic Cooling fan
A thermostat controls the flow of water not the activation of the fan.
Does the engine remain cool when being driven at a fairly constant speed?
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 25th January 2013   #3
JObrien
JObrien is
has no status.
Member
Was going to point out what Madnoel said, but he beat me to it.
I'd get a voltage metre and inspect the radiator fan connections. Also, As Madnoel also asked, Does it remain cool when driving?
Currently in JObrien's garage:
Renault Megane Scenic
JObrien is offline   Reply With Quote Quick reply to this message
Old 25th January 2013   #4
bugsb
bugsb is
at home
Platinum member
bugsb's Avatar
Nominated 14 Times in 11 Posts
i would also be checking the temp sensor as well
Ron
Currently in bugsb's garage:
MGF 1.8 1999/honda hrv 2002
bugsb is online now   Reply With Quote Quick reply to this message
Reply
Tags
cooling, fan, renault, scenic
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
