Removing clio starter motor - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 1st September 2011   #1
joshmully
joshmully is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
anybody know why i cant get the motor off?
My clio wont start at all... it been gettin worse at startin over the past few weeks and now when i turn the key nothing happens. i have started to take the starter motor off to try a new one... i have disconnected the power cable and solenoid and undone the two holding bolts (on the right side of the motor looking down past the air filter) and i cant get it to move?? I cant find any more bolts holding it in??
Currently in joshmully's garage:
2000 Renault Clio II 1.4 S
joshmully is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by joshmully
Removing clio starter motor Engines joshmully 4 3852 1st September 2011 09:36 PM
Radiator fan Engines Lagdti 6 1164 2nd January 2011 10:07 PM
Sponsored Links
Advertisement
Old 2nd September 2011   #2
Ralph
Ralph is
Laid back
Platinum member
Ralph's Avatar
Nominated 2 Times in 8 Posts
Nominated TOTW/F/M Award(s): 4
Re: Removing clio starter motor
There are 3 one is on the left level with the top right one.
__________________
Ralph's 4th law of motion states that any dropped object will immediately hide under a larger object.
If you find a fix for your problem please let us know it will help others.
Ralph Nr Fleetwood NW UK.
Currently in Ralph's garage:
Clio 15 DCi 80, Motomorini 3 1/2, Yamaha MT-07, LMS 5MT 3 1/2 inch Gauge.
Ralph is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to Ralph For This Useful Post:
joshmully (2nd September 2011)
Old 2nd September 2011   #3
joshmully
joshmully is
has no status.
Junior Member
Threadstarter
Yeah i got it off today cheers!!! Puttin the other one on tomorrow so hopin its the starter thats gone!!
Old 2nd September 2011   #4
Ralph
Ralph is
Laid back
Platinum member
Ralph's Avatar
Hi Josh
Did you get it out upwards or from under the car? did you have to take anything else off?
Old 3rd September 2011   #5
joshmully
joshmully is
has no status.
Junior Member
Threadstarter
Hi Ralph
First i took the power cable and solenoid off from underneath the car, then i went to the top and took the air filter off and then the three holdin bolts, two are together and the other is seperate and like an inch or two closer to the front of the car. i cant remember if you actually need to take the air filter off, just know it helped me see where i was goin and work out which last bolt needed to come off..
Reply
Tags
clio, motor, removing, starter
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
